Compiler Bug?
Can anyone tell me why the compiler complains that "Case value is not a constant" when the file only contains constants?
MODULE_NAME='Switch Case Test'
(*  FILE CREATED ON: 07/09/2015  AT: 09:46:02              *)
(*  FILE_LAST_MODIFIED_ON: 07/09/2015  AT: 09:57:33        *)
(* System Type : NetLinx                                   *)
(* REV HISTORY:                                            *)
    $History: $
(*               CONSTANT DEFINITIONS GO BELOW             *)
DEFINE_CONSTANT
cnCommand1         = 1
cnCommand2         = 2
cnCommand3         = 3
cnCommand4         = 4
cnCommand5         = 5
cnCommand6         = 6
cnCommand7         = 7
cnCommand8         = 8
cnCommand9         = 9
cnCommand10     = 10
char sCmds[10][16] =
    {'command_1'},
    {'command_2'},
    {'command_3'},
    {'command_4'},
    {'command_5'},
    {'command_6'},
    {'command_7'},
    {'command_8'},
    {'command_9'},
    {'command_10'}
(*              DATA TYPE DEFINITIONS GO BELOW             *)
DEFINE_TYPE
(*               LATCHING DEFINITIONS GO BELOW             *)
DEFINE_LATCHING
(*       MUTUALLY EXCLUSIVE DEFINITIONS GO BELOW           *)
DEFINE_MUTUALLY_EXCLUSIVE
(*        SUBROUTINE/FUNCTION DEFINITIONS GO BELOW         *)
define_function parseResponse(char sResponse[])
    stack_var char sCommand[64]
    sCommand         = remove_string(sResponse, "13,10", 1)
    switch(sCommand)
        case sCmds[cnCommand1]:
            //  Do something
(*                STARTUP CODE GOES BELOW                  *)
(*                THE EVENTS GO BELOW                      *)
(*            THE ACTUAL PROGRAM GOES BELOW                *)
DEFINE_PROGRAM
(*                     END OF PROGRAM                      *)
(*        DO NOT PUT ANY CODE BELOW THIS COMMENT           *)
    a_riot42 wrote: »
    help file wrote:
    The value of the SWITCH expression is tested against each CASE value (a numeric constant or a string literal).
    Maybe because it?s an array? An array of constants but it?s still an array. Don?t know for sure but that would be my guess.
    This is just another example of why I almost always stick with Select Active unless the Switch Case contains a bunch of Cases with constants (as in 1, 2, 3, etc.) that are in numerical order. In my opinion, there are too many gotchas with Switch Case that makes it just not worth using. Select Active may be a bit more verbose but the flexibility and lack of any type of issues makes it worthwhile in my mind.
    I've noticed this kind of stuff a lot lately. In general it seems to occur when you use an array in some kind of conditional. for example: I just did project where this would not work.
    define_function fn_MyFunction(integer tp_id){
        if(Some_Intefger_Arraty[tp_id]){
          // if a value in the cell referenced - do something
    but - do this and it works fine.
        stack_var integer MyValue;
        MyValue=Some_Intefger_Arrat[tp_id];
        if(MyValue){
    the behavior seemed to be the same when used in the "Switch" of a switch/case or even in the "case"
    You might try throwing in a stack_var and transfering the value to it and see if it works.
    I can work around it easily enough but was curious if there was an error I was making. Silliness.
    I think in this case it's more an issue being a constant array rather than one of the quirks associated with a switch case since you can't pass a constant to a module but you can if it's an element of a constant array so it's almost like the compiler interprets a constant array element as a variable not a constant.
    vining wrote: »
    Then it seems to be there is no such thing as a constant array, although a string is an array of characters which can be a constant so its not consistent. I switched to if-else which should do the same thing without enraging the compiler. Strange that I hadn't come across this before.
    a_riot42 wrote: »
    I wonder if (just for the sheer mindlessness of it) you populated a non-arrayed stack_var just prior to the switch/case if it would work? something like
    stack_var char MyString_01[16];
    stack_var char MyString_02[16];
    stack_var char MyString_03[16];
    // etc...
    then
    MyString_01=sCMDs[01];
    MyString_02=sCMDs[02];
    MyString_03=sCMDs[03];
    // etc..
    then
    switch(sCommand):{
    case MyString_01:{
    // do something
    case MyString_02:{
    // do something
    case MyString_03:{
    // do something
    // etc.....
  • PhreaKPhreaK Posts: 966
    You can't build case statements around stack_var's - the values need to be constant.
    PhreaK wrote: »
    That's what I thought too. And actually, that's how I've always done it. It was just a thought to see if the whole "Using" and array of constants" could be overcome.
    Yeah, it sucks but switch case statements are handled at compile time as they are generally optimised out to a jump table or something a binary search can be run on.
    Interestingly, it looks like the issue here is with the current compiler not acknowledging the array is constant. Regardless of the way the way a constant array is defined (both within define_constant, or in define_variable and prefixed with 'constant') you can write compilable code that assigns a new value to specific indices. This does however throw a runtime error.
