How to reset overloaded mvp-5200i ?
Draugar
Hi,
My colleague have managed to upload a heavy program to an mvp-5200i panel, which have made it extremely slow. I am able to navigate to setup menu but I am not able to do system recovery due to heavy load on the unit. (using 10-20 minutes to get into setup menu, buttons react anything between 5 seconds and 2 minutes when pressed, if lucky)
I cannot connect it to network and telnet in as buttons not reacting.
If I get a USB cable, is there a way to factory reset via USB?
Thanks for reply!
Thanks for reply!
I was able to overload a CV7 with a 50Meg file, but luckily the firmware picked up there was no memory left and asked if I wanted to delete the user files.
As John said if you let the panel deplete its battery, or you manage to reboot it you may see the same message I saw. I don't recall if the message was after loading the file from TPD or after a reboot
I am sorry for late respond. I thought I closed this already with a description.
I managed to get it reset to factory by acting very quick after reboot. If I acted too slow, the panel would become useless again.
The problem were that I borrowed my testpanel to my coleague who were working with some "#?%&/ G5 stuff, and the result were like a 20 year old computer running Windows vista on a 8080 CPU and five RPM drive. To reboot were no issue, jsut hold the button long enough (if I remember correctly, somewhat over 2 minutes)
Panel is working like normal now
Thanks anyway!
