NXC-VAI4 card pb!!!
techniquesmethodes
in AMX Hardware
hello every one,
In one of my systems I use a NXC - VAI4 card for driving solenoids, recently INPUT LEDs blink constantly and my solenoid get nothing of the card. I was able to control the card via NetLinx Studio using send_command any ideas plzz!!
They typical way solenoids are done is to use AMX Relays and then run the circuit with a stand-alone power supply beefy enough to drive the solenoids.
The problem came from a 24V cable that touched the metal part of the valve. The card is dead , no voltage on the OUTPUT
well, like I said before - I'd use a relay and separate power supply. This also adds the benefit of isolating the control system components from the other system. You were lucky it was just a card that burned up. It could have been much worse.
