CP-3008
Hi,
Is the CP-3008 Network Connection for RMS only or can you use it for device control as well? All info seems to be a bit vague on this.
Cheers!
    RaphayoRaphayo Posts: 111
    d_gavin wrote: »
    Hi,
    Cheers!
    If i remember a discussion with our rep, it can be use only with rms.
    Yes, Only RMS.
    The new Massio line will do both as i understood
    The massio will be programmable from rpm only.
    Raphayo wrote: »
    Why do they make a product that finally looks like it might be useful and actually work in this market, then turn it into a piece of rubbish by allowing RPM programming only?? I tried to sign up to RPM a few weeks ago, never heard anything back..
    Talk to a AMX rep.
    Shouldnt be a problem??
    mGaughanmGaughan Posts: 10
    We just received on for testing and it seems this is correct. It did look like a great product, but RPM only seems unnecessarily limiting. From what I can tell RPM only supports AMX video switchers. Our plan was to update our classroom systems using this controller, but they use non-AMX scalers. If anyone can tell me how to use other scalers in RPM or program using NS I would really love it! (NS would be preferred.)
