No, haven't bought one yet. The control API is pretty straight forward but I haven't had the time or the need to write a module for it. Seems everytime I spend a few hundred hours writing a module for a device it becomes obsolete.
I'm in the middle of writing a Netlinx module for the HEOS. It actually came with an API, unlike the Sonos, so it hopefully won't end up being a waste of time. We'll see....
Paul, have you ever finished this? I'm on the fence about specifying AMX in a bid I'm working on but I want to use Heos or possibly Sonos but apparently AMX is the only company that doesn't supply a modules to their dealers for either and I'm at the point where I won't write one myself. Supposedly RocketGUI has a mod for $500 but I'm sure that's only available in tko form so future support hinges on them staying in the AMX game and I won't bank on that.
I know it's probably a waste of time even considering AMX but I have a hard time letting go so I'll at least see if it's possible, crunch the numbers and see how much less my other option will be. If I assume the RocketGUI cost and iPad / phone licenses just that makes AMX $2k+ more.
Have you finished the Denon Heos Mod yet as i am thinking of using this in a job and not sure if its worth doing.
Is there any problems you have encountered ?
Many Thanks .
I would investigate the RockeGui module, I have no experience with it myself but it looks promising.
Many Thanks .
https://www.rocketgui.com/?TotalMusicHeosAMX
