Determine own IP address
Does anyone know if there is a way to determine the IP address assigned to a master from within Netlinx? I want to have the code determine the IP of the master, picked up via DHCP, and then do some configuration depending on what the IP is.
Here is an example how to get the address of the NI.
DEFINE_DEVICE dvMaster = 0:1:0 dvTP = 10001:1:0 DEFINE_FUNCTION PrintIP() { IP_ADDRESS_STRUCT IPInfo GET_IP_ADDRESS(dvMaster,IPInfo) SEND_STRING 0,"'My IP Address is: ',IPInfo.IPADDRESS" } DEFINE_EVENT BUTTON_EVENT[dvTP,1] { PUSH: {PrintIP()} }After I push button 1:
