Studio 2.2 problem viewing AXI files.
Is there a solution to the problem in the latest build of Studio2.2 where when viewing a NetLinx axi file, it is scene as an Axcess axi file. The file still compiles as a NetLinx file but it effects the key word colors and can make the file hard to read. Is there a setting problem or is this a bug and if so is there a fix on the way?
Robb
  • File needs to have the proper orphan file type designation and if in a multi-system project needs to be opened with its system active. Reply form AMX in a previous posting indicates that the issue is resolved with the next release.
  • RWozneyRWozney Posts: 19
    Ok, so can you change the orphan file type designation?
