Commercial Skip
Hello, I want to create some code that references another button for the purpose of skipping commercials. My code is as follows:
// UVERSE Controls
BUTTON_EVENT[vdvTP,38]
BUTTON_EVENT[vdvTP,39]
BUTTON_EVENT[vdvTP,40]
BUTTON_EVENT[vdvTP,41]
BUTTON_EVENT[vdvTP,42]
BUTTON_EVENT[vdvTP,43]
BUTTON_EVENT[vdvTP,44]
BUTTON_EVENT[vdvTP,45]
BUTTON_EVENT[vdvTP,46]
BUTTON_EVENT[vdvTP,47]
BUTTON_EVENT[vdvTP,48]
BUTTON_EVENT[vdvTP,49]
BUTTON_EVENT[vdvTP,50]
BUTTON_EVENT[vdvTP,51]
BUTTON_EVENT[vdvTP,52]
BUTTON_EVENT[vdvTP,53]
BUTTON_EVENT[vdvTP,54]
BUTTON_EVENT[vdvTP,55]
BUTTON_EVENT[vdvTP,56]
BUTTON_EVENT[vdvTP,57]
BUTTON_EVENT[vdvTP,58]
BUTTON_EVENT[vdvTP,59]
BUTTON_EVENT[vdvTP,60]
BUTTON_EVENT[vdvTP,61]
BUTTON_EVENT[vdvTP,62] // Record
BUTTON_EVENT[vdvTP,63]
BUTTON_EVENT[vdvTP,64]
BUTTON_EVENT[vdvTP,65]
BUTTON_EVENT[vdvTP,66]
BUTTON_EVENT[vdvTP,67]
BUTTON_EVENT[vdvTP,68] // Skip 7 seconds FF
BUTTON_EVENT[vdvTP,69]
BUTTON_EVENT[vdvTP,70] // Commercial Skip (5 times Skip)
TO [UVERSE,BUTTON.INPUT.CHANNEL-37]
As you can [vdvTP,68] can be pressed 5 times to get the required results, but how can I write the code for button 70 to run 5 times?
Thanks, Donald
// UVERSE Controls
Thanks, Donald
BUTTON_EVENT[vdvTP,65] BUTTON_EVENT[vdvTP,66] BUTTON_EVENT[vdvTP,67] BUTTON_EVENT[vdvTP,68] // Skip 7 seconds FF BUTTON_EVENT[vdvTP,69] BUTTON_EVENT[vdvTP,70] // Commercial Skip (5 times Skip) { PUSH: { STACK_VAR INTEGER nBtn; LOCAL_VAR INTEGER nCnt; nBtn = BUTTON.INPUT.CHANNEL-37; if(nBtn == 33)//70 { if(nCnt < 5) { nCnt++; SEND_COMMAND UVERSE,"'SP',nBtn"; WAIT 6 'COMMERCIAL_SKIP'//assumes sp time left at 5 (set CTON and CTOF in online event) { DO_PUSH_TIMED(vdvTP,70,1); } } else //send pulse # 5, reset count { nCnt = 0; SEND_COMMAND UVERSE,"'SP',nBtn"; } } else { if(nCnt && nCnt<5)//commerial skip in progress but another button pushed so abort { CANCEL_WAIT'COMMERCIAL_SKIP'; SEND_COMMAND UVERSE,"'CP',33;//clear any backed up commands nCnt = 0; } else if(nCnt)//just in case { nCnt = 0; } SEND_COMMAND UVERSE,"'SP',nBtn"; } }yeah, I suppose I'm just lazy.
