NEC E424 RS232 Not working
I've created this module in efforts of adding on to it, but I can't even get the power to work. I've tried using ASCII, Hex, and a combination of both. The power codes, directly from thier manual, don't work. When I power the TV on manually, the HDMI input code works fine.
MODULE_NAME='NEC E424' (DEV dvTV, DEV vdvTV)
(* FILE CREATED ON: 08/03/2015 AT: 10:25:19 *)
(* FILE_LAST_MODIFIED_ON: 09/23/2015 AT: 11:40:50 *)
DEFINE_CONSTANT // TV Channels and Levels
// TV Channels
POWER = 9 // Momentary: Cycle power
DIGIT_0 = 10 // Momentary: Press menu button digit 0
DIGIT_1 = 11 // Momentary: Press menu button digit 1
DIGIT_2 = 12 // Momentary: Press menu button digit 2
DIGIT_3 = 13 // Momentary: Press menu button digit 3
DIGIT_4 = 14 // Momentary: Press menu button digit 4
DIGIT_5 = 15 // Momentary: Press menu button digit 5
DIGIT_6 = 16 // Momentary: Press menu button digit 6
DIGIT_7 = 17 // Momentary: Press menu button digit 7
DIGIT_8 = 18 // Momentary: Press menu button digit 8
DIGIT_9 = 19 // Momentary: Press menu button digit 9
MENU_PLUS_10 = 20 // Momentary: Press menu button plus_10
MENU_ENTER = 21 // Momentary: Press menu button enter
CHAN_UP = 22 // Momentary: Next station preset
CHAN_DN = 23 // Momentary: Previous station preset
VOL_UP = 24 // Ramping: Ramp volume up
VOL_UP_FB = 24 // Feedback: Volume ramp up feedback
VOL_DN = 25 // Ramping: Ramp volume down
VOL_DN_FB = 25 // Feedback: Volume ramp down feedback
VOL_MUTE = 26 // Momentary: Cycle volume mute
PWR_ON = 27 // Momentary: Set power on
PWR_OFF = 28 // Momentary: Set power off
SOURCE_TV1 = 30 // Momentary: *deprecated Input Source in favor of Input Select* TV 1 source select
SOURCE_VIDEO1 = 31 // Momentary: *deprecated Input Source in favor of Input Select* Video 1 source select
SOURCE_VIDEO2 = 32 // Momentary: *deprecated Input Source in favor of Input Select* Video 2 source select
SOURCE_VIDEO3 = 33 // Momentary: *deprecated Input Source in favor of Input Select* Video 3 source select
SOURCE_TAPE1 = 34 // Momentary: *deprecated Input Source in favor of Input Select* Tape 1 source select
SOURCE_TAPE2 = 35 // Momentary: *deprecated Input Source in favor of Input Select* Tape 2 source select
SOURCE_CD1 = 36 // Momentary: *deprecated Input Source in favor of Input Select* CD 1 source select
SOURCE_TUNER1 = 37 // Momentary: *deprecated Input Source in favor of Input Select* Tuner 1 source select
SOURCE_PHONO1 = 38 // Momentary: *deprecated Input Source in favor of Input Select* Phono 1 source select
SOURCE_AUX1 = 39 // Momentary: *deprecated Input Source in favor of Input Select* Auxiliary 1 source select
TUNER_BAND = 40 // Momentary: Cycle tuner band
MENU_CANCEL = 43 // Momentary: Press menu button cancel
MENU_FUNC = 44 // Momentary: Press menu button menu
MENU_UP = 45 // Momentary: Press menu up button
MENU_DN = 46 // Momentary: Press menu down button
MENU_LT = 47 // Momentary: Press menu left button
MENU_RT = 48 // Momentary: Press menu right button
MENU_SELECT = 49 // Momentary: Press menu Select button (select current item under cursor)
MENU_EXIT = 50 // Momentary: Press menu button exit
MENU_UP_LT = 51 // Momentary: Press menu up left button
MENU_UP_RT = 52 // Momentary: Press menu up right button
MENU_DN_LT = 53 // Momentary: Press menu down left button
MENU_DN_RT = 54 // Momentary: Press menu down right button
MENU_VIDEO = 57 // Momentary: Press menu button video
MENU_THUMBS_DN = 58 // Momentary: Press menu button thumbs down
MENU_THUMBS_UP = 59 // Momentary: Press menu button thumbs up
MENU_ACCEPT = 60 // Momentary: Press menu button accept
MENU_REJECT = 61 // Momentary: Press menu button reject
MENU_LIVE_TV = 62 // Momentary: Press menu button live TV
MENU_SLEEP = 63 // Momentary: Press menu button sleep
MENU_PPV = 64 // Momentary: Press menu button PPV
MENU_FUNCTION = 65 // Momentary: Press menu button function
MENU_SETUP = 66 // Momentary: Press menu button setup
MENU_XM = 77 // Momentary: Press menu button xm
MENU_FM = 78 // Momentary: Press menu button fm
MENU_AM = 79 // Momentary: Press menu button am
MENU_CLEAR = 80 // Momentary: Press menu button clear
MENU_BACK = 81 // Momentary: Press menu button back
MENU_FORWARD = 82 // Momentary: Press menu button forward
MENU_ADVANCE = 83 // Momentary: Press menu button advance
MENU_DIMMER = 84 // Momentary: Press menu button dimmer
MENU_HOLD = 85 // Momentary: Press menu button hold
MENU_LIST = 86 // Momentary: Press menu button list
MENU_LT_PAREN = 87 // Momentary: Press menu button left paren
MENU_RT_PAREN = 88 // Momentary: Press menu button right paren
MENU_UNDERSCORE = 89 // Momentary: Press menu button underscore
MENU_DASH = 90 // Momentary: Press menu button dash
MENU_ASTERISK = 91 // Momentary: Press menu button asterisk
MENU_DOT = 92 // Momentary: Press menu button dot
MENU_POUND = 93 // Momentary: Press menu button pound
MENU_COMMA = 94 // Momentary: Press menu button comma
MENU_DIAL = 95 // Momentary: Press menu button dial
MENU_CONFERENCE = 96 // Momentary: Press menu button conference
MENU_PLUS_100 = 97 // Momentary: Press menu button plus_100
MENU_PLUS_1000 = 98 // Momentary: Press menu button plus_1000
MENU_DISPLAY = 99 // Momentary: Press menu button display
MENU_SUBTITLE = 100 // Momentary: Press menu button subtitle
MENU_INFO = 101 // Momentary: Press menu button info
MENU_FAVORITES = 102 // Momentary: Press menu button favorites
MENU_CONTINUE = 103 // Momentary: Press menu button continue
MENU_RETURN = 104 // Momentary: Press menu button return
MENU_GUIDE = 105 // Momentary: Press menu button guide
MENU_PAGE_UP = 106 // Momentary: Press menu button page up
MENU_PAGE_DN = 107 // Momentary: Press menu button page down
MENU_DECK_A_B = 108 // Momentary: Press menu button deck AB
MENU_TV_VCR = 109 // Momentary: Press menu button TV VCR
MENU_RECORD_SPEED = 110 // Momentary: Press menu button record speed
MENU_PROGRAM = 111 // Momentary: Press menu button program
MENU_AB_REPEAT = 112 // Momentary: Press menu button AB repeat
MENU_HELP = 113 // Momentary: Press menu button help
MENU_TITLE = 114 // Momentary: Press menu button title
MENU_TOP_MENU = 115 // Momentary: Press menu button top menu
MENU_ZOOM = 116 // Momentary: Press menu button zoom
MENU_ANGLE = 117 // Momentary: Press menu button angle
MENU_AUDIO = 118 // Momentary: Press menu button audio
MENU_PREVIEW_INPUT = 129 // Momentary: Press menu button preview input
MENU_SEND_INPUT = 130 // Momentary: Press menu button send input
MENU_SEND_GRAPHICS = 131 // Momentary: Press menu button send graphics
VOL_PRESET = 138 // Momentary: Cycle volume preset
ASPECT_RATIO = 142 // Momentary: Cycle aspect ratio
BRIGHT_UP = 148 // Momentary: Increment brightness
BRIGHT_DN = 149 // Momentary: Decrement brightness
COLOR_UP = 150 // Momentary: Increment color
COLOR_DN = 151 // Momentary: Decrement color
CONTRAST_UP = 152 // Momentary: Increment contrast
CONTRAST_DN = 153 // Momentary: Decrement contrast
SHARP_UP = 154 // Momentary: Increment sharpness
SHARP_DN = 155 // Momentary: Decrement sharpness
TINT_UP = 156 // Momentary: Increment tint
TINT_DN = 157 // Momentary: Decrement tint
PIP_POS = 191 // Momentary: Cycle pip position
PIP_SWAP = 193 // Momentary: Swap pip
PIP = 194 // Momentary: Cycle pip
PIP_ON = 195 // Discrete: Set pip on
PIP_FB = 195 // Feedback: Pip feedback
SOURCE_CYCLE = 196 // Momentary: *deprecated Input Source in favor of Input Select* Cycle source select
VOL_MUTE_ON = 199 // Discrete: Set volume mute
VOL_MUTE_FB = 199 // Feedback: Volume mute feedback
MENU_FLASH = 203 // Momentary: Press menu button flash
PIC_MUTE = 210 // Momentary: Cycle picture/video mute
PIC_MUTE_ON = 211 // Discrete: Set picture/video mute on
PIC_MUTE_FB = 211 // Feedback: Picture/video mute feedback
PIC_FREEZE = 213 // Momentary: Cycle freeze
PIC_FREEZE_ON = 214 // Discrete: Set freeze on
PIC_FREEZE_FB = 214 // Feedback: Freeze feedback
MENU_RESET = 215 // Momentary: Press menu button reset
MENU_INSTANT_REPLAY = 218 // Momentary: Press menu button instant replay
TUNER_PRESET_GROUP = 224 // Momentary: Cycle station preset group
TUNER_STATION_UP = 225 // Momentary: Increment tuner station
TUNER_STATION_DN = 226 // Momentary: Decrement tuner station
TUNER_SCAN_FWD = 227 // Momentary: Station scan forward
TUNER_SCAN_REV = 228 // Momentary: Station scan backward/reverse
TUNER_SEEK_FWD = 229 // Momentary: Station seek forward
TUNER_SEEK_REV = 230 // Momentary: Station seek backward/reverse
TUNER_OSD = 234 // Momentary: Cycle on-screen or front panel display info
TUNER_PREV = 235 // Momentary: Goto previous tuner station
DEVICE_COMMUNICATING = 251 // Feedback: Device online event
DATA_INITIALIZED = 252 // Feedback: Data initialized event
POWER_ON = 255 // Discrete: Set power
POWER_FB = 255 // Feedback: Power feedback
// TV Levels
VOL_LVL = 1 // Level: Volume level (0-255)
BRIGHT_LVL = 10 // Level: Brightness level (0-255)
COLOR_LVL = 11 // Level: Color level (0-255)
CONTRAST_LVL = 12 // Level: Contrast level (0-255)
SHARP_LVL = 13 // Level: Sharpness level (0-255)
TINT_LVL = 14 // Level: Tint level (0-255)
//USER DEFINED CONSTANTS
SOURCE_VIDEO4 = 256
SOURCE_VIDEO5 = 257
SOURCE_VIDEO6 = 258
ASPECT_16 = 259
ASPECT_4 = 260
Auto_Size = 261
Aspect_Zoom = 262
(* DATA TYPE DEFINITIONS GO BELOW *)
DEFINE_TYPE
(* VARIABLE DEFINITIONS GO BELOW *)
NON_VOLATILE CHAR cMsg[25]
(* STARTUP CODE GOES BELOW *)
CREATE_BUFFER dvTV, cMsg
(* LATCHING DEFINITIONS GO BELOW *)
DEFINE_LATCHING
(* MUTUALLY EXCLUSIVE DEFINITIONS GO BELOW *)
DEFINE_MUTUALLY_EXCLUSIVE
(* SUBROUTINE/FUNCTION DEFINITIONS GO BELOW *)
(* THE EVENTS GO BELOW *)
DATA_EVENT[dvTV]
ONLINE:
SEND_COMMAND dvTV, "'SET BAUD 9600,N,8,1'" //Sets baud rate
SEND_COMMAND dvTV, "'RXON'" //starts serial port
SEND_COMMAND dvTV, "'HSOFF'" //turns handshaking off
ON[dvTV,DEVICE_COMMUNICATING]
OFFLINE:
OFF[dvTV, DEVICE_COMMUNICATING]
STRING:
SEND_STRING 0, "'FROM TV: ',cMsg"
CHANNEL_EVENT[vdvTV, PWR_ON]
CHANNEL_EVENT[vdvTV, PWR_OFF]
CHANNEL_EVENT[vdvTV, SOURCE_VIDEO1]
ON:
SWITCH(CHANNEL.CHANNEL)
CASE PWR_ON: SEND_STRING dvTV, "$01,$30,$41,$30,$41,$30,$43,$02,$43,$32,$30,$33,$44,$36,$30,$30,$30,$31,$03,$73,$0d"
CASE PWR_OFF: SEND_STRING dvTV, "$01,$30,$41,$30,$41,$30,$43,$02,$43,$32,$30,$33,$44,$36,$30,$30,$30,$34,$03,$76,$0d"
CASE SOURCE_VIDEO1: SEND_STRING dvTV, "$01,$30,$41,$30,$45,$30,$41,$02,$30,$30,$36,$30,$30,$30,$31,$31,$03,$72,$0d"
The power strings look correct. They are the same for many (if not all) of the NEC E series TVs.
I had a power issue with one of the E4 series TV but I don?t remember exactly which model it was. Power ON didn?t work anymore and power OFF was actually doing a power TOGGLE. NEC confirmed it was a firmware bug. I don?t know if this is the same problem that you are experiencing but I would issue a power OFF command when the TV is OFF and see if it turns ON.
I would also make sure the energy mode is turned off if it is not off already.
And lastly I would cold boot the TV as that sometimes fixed the RS-232 comms.
Good luck.
Also download PD comms tool (http://www.necdisplay.com/support-and-services/pdcommstool/downloads) to test rs-232 commands.
