Encode to UTF-8 and then decode to TP.
Hello,
My app takes some user data from a TP keyboard.
I need to store that data in UTF-8 format, and then, show the UTF-8 formatted data on the TP again.
What i'm trying so far is:
1.- Encode the data received from the keyboard to UTF-8.
2.- Take the encoded data and show it on the TP:
But, the text at the TP is in blank.
I've also tried other ways to implement similar tests using _WC and wc_to_char or char_to_wc, but none worked for me.
Thanks for your help!!
wcAux = wc_decode(acDataText,WC_FORMAT_TP,1) scStudyCase.Patient.Name = wc_encode(wcAux,WC_FORMAT_UTF8,1)
wcAux = wc_decode(acAux,WC_FORMAT_UTF8,1)
acAux = wc_tp_encode(wcAux)
send_command dvTp, "'^UNI-',itoa(anAddressItemData[nAux][4]),',0,',acAux"
DEFINE_FUNCTION fnFB_DoSend_VT(INTEGER iUI_Indx,INTEGER iCHAN,CHAR iStrMSG[]) { STACK_VAR INTEGER n; STACK_VAR INTEGER nTPCount; STACK_VAR INTEGER nLoopStart; STACK_VAR CHAR cUNI_STR_2[MAX_4096]; STACK_VAR WIDECHAR cUNI_STR_1[MAX_4096]; if(iUI_Indx) { nTPCount = iUI_Indx; nLoopStart = iUI_Indx; } else { nTPCount = sSBS.sPlayer.nNum_UIs; nLoopStart = 1; } fnDevMod_DEBUG("'SEND_VT: ',iStrMSG,' :DEBUG<',ITOA(__LINE__),'>'",4); if(length_string(iStrMSG)) { cUNI_STR_1 = WC_DECODE(fnStrReplace(iStrMSG,'$; ',', '),WC_FORMAT_UTF8,1); cUNI_STR_2 = WC_ENCODE(cUNI_STR_1,WC_FORMAT_TP,1); } for(n = nLoopStart; n <= nTPCount; n++) { if(nUI_ActiveArry[n] == sSBS.sPlayer.nInstance)//means it on this SB & ACTIVE on page { SWITCH(nUI_TypeArry[n]) { CASE UI_TYPE_iPHONE: CASE UI_TYPE_iTOUCH: CASE UI_TYPE_iPAD: CASE UI_TYPE_G4: CASE UI_TYPE_R4: CASE UI_TYPE_MIO_DMS: { if(length_string(cUNI_STR_2)) { STACK_VAR CHAR cUniSend[MAX_4096]; STACK_VAR INTEGER nAppend; cUniSend = cUNI_STR_2; WHILE(LENGTH_STRING(cUniSend)) { STACK_VAR CHAR cTMP[UNI_STR_SIZE]; if(LENGTH_STRING(cUniSend) > UNI_STR_SIZE) { cTMP = GET_BUFFER_STRING(cUniSend,UNI_STR_SIZE); } else { cTMP = GET_BUFFER_STRING(cUniSend,LENGTH_STRING(cUniSend)); } if(nAppend) { SEND_COMMAND dvUI_SBSArry[n],"'^BAU-',ITOA(iCHAN),',0,',cTMP"; //Append Unicode to Modero Panels } else { SEND_COMMAND dvUI_SBSArry[n],"'^UNI-',ITOA(iCHAN),',0,',cTMP"; //Unicode to Modero Panels } fnDevMod_DEBUG("'SEND_COMMAND UNI, APPEND-[',itoa(nAppend),'], CHNL-[',itoa(iCHAN),'], STR-[ ',cTMP,' ] :DEBUG<',ITOA(__LINE__),'>'",4); nAppend++; } } else//we need to clear text fields too, duh! { SEND_COMMAND dvUI_SBSArry[n], "'^TXT-',itoa(iCHAN),',0,',cUNI_STR_2"; } } CASE UI_TYPE_G3: { fnDevMod_DEBUG("'^TXT- TP INDX: ',itoa(n),', CHNL: ',itoa(iCHAN),' :DEBUG<',ITOA(__LINE__),'>'",4); SEND_COMMAND dvUI_SBSArry[n], "'^TXT-',itoa(iCHAN),',0,',iStrMSG"; } CASE UI_TYPE_METKP: CASE UI_TYPE_UNKNOWN: CASE UI_TYPE_VIRTUAL: { //DO NOTHING } } } } RETURN; }finally, the solution was that i was receiving data from the TP input fields in ASCII format, so i just had to decode the ASCII data and encode it in UTF-8.
The code:
wcAux = wc_decode(texto,WC_FORMAT_ASCII,1) acAux = wc_encode(wcAux,WC_FORMAT_UTF8,1) scStudyCaseSearch.Patient.FamilyName = acAuxThen, with the data in UTF-8, i can properly store latin characters and use them in a server-PC's database.
Salutes!
