RE-DM 6 Radia Eclipse dimmer circuit schematics
ajish.raju
in AMX Hardware
Got an out of warranty unit which keeps throwing out phase error and is not able to controlled. I was thinking if anyone has any idea on schematics so that i can hack the unit and get it back to working state.
It may well be improper wiring (not at your end of the copper but somewhere down the line.)
Of course you also have phase concerns on the load side whether the load requires leading edge or lagging edge dimming (forward or reverse phase), typical the difference between an electronic low voltage dimmer and a magnetic/incandescent dimmer.
