Christie DWU600-G Projector
mjones2620
Having issues parsing the lamp hours from this projector. Re-using a similiar module I created for the LWU505 which worked fine. Seems like they changed thier syntax, which I dont know why. When I use SEND_STRING 0 I get LAMP_HOURS=
MODULE_NAME='Christie DWU600' (DEV dvVP,DEV vdvVP) (***********************************************************) (* FILE_LAST_MODIFIED_ON: 09/24/2015 AT: 13:38:54 *) (***********************************************************) (***********************************************************) (* CONSTANT DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_CONSTANT // Video Projector Channels POWER = 9 // Momentary: Cycle lamp power DIGIT_0 = 10 // Momentary: Press menu button digit 0 DIGIT_1 = 11 // Momentary: Press menu button digit 1 DIGIT_2 = 12 // Momentary: Press menu button digit 2 DIGIT_3 = 13 // Momentary: Press menu button digit 3 DIGIT_4 = 14 // Momentary: Press menu button digit 4 DIGIT_5 = 15 // Momentary: Press menu button digit 5 DIGIT_6 = 16 // Momentary: Press menu button digit 6 DIGIT_7 = 17 // Momentary: Press menu button digit 7 DIGIT_8 = 18 // Momentary: Press menu button digit 8 DIGIT_9 = 19 // Momentary: Press menu button digit 9 MENU_PLUS_10 = 20 // Momentary: Press menu button plus_10 MENU_ENTER = 21 // Momentary: Press menu button enter VOL_UP = 24 // Ramping: Ramp volume up VOL_UP_FB = 24 // Feedback: Volume ramp up feedback VOL_DN = 25 // Ramping: Ramp volume down VOL_DN_FB = 25 // Feedback: Volume ramp down feedback VOL_MUTE = 26 // Momentary: Cycle volume mute PWR_ON = 27 // Momentary: Set lamp power on PWR_OFF = 28 // Momentary: Set lamp power off SOURCE_TV1 = 30 // Momentary: *deprecated Input Source in favor of Input Select* TV 1 source select SOURCE_VIDEO1 = 31 // Momentary: *deprecated Input Source in favor of Input Select* Video 1 source select SOURCE_VIDEO2 = 32 // Momentary: *deprecated Input Source in favor of Input Select* Video 2 source select SOURCE_VIDEO3 = 33 // Momentary: *deprecated Input Source in favor of Input Select* Video 3 source select SOURCE_TAPE1 = 34 // Momentary: *deprecated Input Source in favor of Input Select* Tape 1 source select SOURCE_TAPE2 = 35 // Momentary: *deprecated Input Source in favor of Input Select* Tape 2 source select SOURCE_CD1 = 36 // Momentary: *deprecated Input Source in favor of Input Select* CD 1 source select SOURCE_TUNER1 = 37 // Momentary: *deprecated Input Source in favor of Input Select* Tuner 1 source select SOURCE_PHONO1 = 38 // Momentary: *deprecated Input Source in favor of Input Select* Phono 1 source select SOURCE_AUX1 = 39 // Momentary: *deprecated Input Source in favor of Input Select* Auxiliary 1 source select MENU_CANCEL = 43 // Momentary: Press menu button cancel MENU_FUNC = 44 // Momentary: Press menu button menu MENU_UP = 45 // Momentary: Press menu up button MENU_DN = 46 // Momentary: Press menu down button MENU_LT = 47 // Momentary: Press menu left button MENU_RT = 48 // Momentary: Press menu right button MENU_SELECT = 49 // Momentary: Press menu Select button (select current item under cursor) MENU_EXIT = 50 // Momentary: Press menu button exit MENU_UP_LT = 51 // Momentary: Press menu up left button MENU_UP_RT = 52 // Momentary: Press menu up right button MENU_DN_LT = 53 // Momentary: Press menu down left button MENU_DN_RT = 54 // Momentary: Press menu down right button MENU_VIDEO = 57 // Momentary: Press menu button video MENU_THUMBS_DN = 58 // Momentary: Press menu button thumbs down MENU_THUMBS_UP = 59 // Momentary: Press menu button thumbs up MENU_ACCEPT = 60 // Momentary: Press menu button accept MENU_REJECT = 61 // Momentary: Press menu button reject MENU_LIVE_TV = 62 // Momentary: Press menu button live TV MENU_SLEEP = 63 // Momentary: Press menu button sleep MENU_PPV = 64 // Momentary: Press menu button PPV MENU_FUNCTION = 65 // Momentary: Press menu button function MENU_SETUP = 66 // Momentary: Press menu button setup MENU_XM = 77 // Momentary: Press menu button xm MENU_FM = 78 // Momentary: Press menu button fm MENU_AM = 79 // Momentary: Press menu button am MENU_CLEAR = 80 // Momentary: Press menu button clear MENU_BACK = 81 // Momentary: Press menu button back MENU_FORWARD = 82 // Momentary: Press menu button forward MENU_ADVANCE = 83 // Momentary: Press menu button advance MENU_DIMMER = 84 // Momentary: Press menu button dimmer MENU_HOLD = 85 // Momentary: Press menu button hold MENU_LIST = 86 // Momentary: Press menu button list MENU_LT_PAREN = 87 // Momentary: Press menu button left paren MENU_RT_PAREN = 88 // Momentary: Press menu button right paren MENU_UNDERSCORE = 89 // Momentary: Press menu button underscore MENU_DASH = 90 // Momentary: Press menu button dash MENU_ASTERISK = 91 // Momentary: Press menu button asterisk MENU_DOT = 92 // Momentary: Press menu button dot MENU_POUND = 93 // Momentary: Press menu button pound MENU_COMMA = 94 // Momentary: Press menu button comma MENU_DIAL = 95 // Momentary: Press menu button dial MENU_CONFERENCE = 96 // Momentary: Press menu button conference MENU_PLUS_100 = 97 // Momentary: Press menu button plus_100 MENU_PLUS_1000 = 98 // Momentary: Press menu button plus_1000 MENU_DISPLAY = 99 // Momentary: Press menu button display MENU_SUBTITLE = 100 // Momentary: Press menu button subtitle MENU_INFO = 101 // Momentary: Press menu button info MENU_FAVORITES = 102 // Momentary: Press menu button favorites MENU_CONTINUE = 103 // Momentary: Press menu button continue MENU_RETURN = 104 // Momentary: Press menu button return MENU_GUIDE = 105 // Momentary: Press menu button guide MENU_PAGE_UP = 106 // Momentary: Press menu button page up MENU_PAGE_DN = 107 // Momentary: Press menu button page down MENU_DECK_A_B = 108 // Momentary: Press menu button deck AB MENU_TV_VCR = 109 // Momentary: Press menu button TV VCR MENU_RECORD_SPEED = 110 // Momentary: Press menu button record speed MENU_PROGRAM = 111 // Momentary: Press menu button program MENU_AB_REPEAT = 112 // Momentary: Press menu button AB repeat MENU_HELP = 113 // Momentary: Press menu button help MENU_TITLE = 114 // Momentary: Press menu button title MENU_TOP_MENU = 115 // Momentary: Press menu button top menu MENU_ZOOM = 116 // Momentary: Press menu button zoom MENU_ANGLE = 117 // Momentary: Press menu button angle MENU_AUDIO = 118 // Momentary: Press menu button audio MENU_PREVIEW_INPUT = 129 // Momentary: Press menu button preview input MENU_SEND_INPUT = 130 // Momentary: Press menu button send input MENU_SEND_GRAPHICS = 131 // Momentary: Press menu button send graphics VOL_PRESET = 138 // Momentary: Cycle volume preset ASPECT_RATIO = 142 // Momentary: Cycle aspect ratio BRIGHT_UP = 148 // Momentary: Increment brightness BRIGHT_DN = 149 // Momentary: Decrement brightness COLOR_UP = 150 // Momentary: Increment color COLOR_DN = 151 // Momentary: Decrement color CONTRAST_UP = 152 // Momentary: Increment contrast CONTRAST_DN = 153 // Momentary: Decrement contrast SHARP_UP = 154 // Momentary: Increment sharpness SHARP_DN = 155 // Momentary: Decrement sharpness TINT_UP = 156 // Momentary: Increment tint TINT_DN = 157 // Momentary: Decrement tint PIP_POS = 191 // Momentary: Cycle pip position PIP_SWAP = 193 // Momentary: Swap pip PIP = 194 // Momentary: Cycle pip PIP_ON = 195 // Discrete: Set pip on PIP_FB = 195 // Feedback: Pip feedback SOURCE_CYCLE = 196 // Momentary: *deprecated Input Source in favor of Input Select* Cycle source select VOL_MUTE_ON = 199 // Discrete: Set volume mute VOL_MUTE_FB = 199 // Feedback: Volume mute feedback MENU_FLASH = 203 // Momentary: Press menu button flash PIC_MUTE = 210 // Momentary: Cycle picture/video mute PIC_MUTE_ON = 211 // Discrete: Set picture/video mute on PIC_MUTE_FB = 211 // Feedback: Picture/video mute feedback PIC_FREEZE = 213 // Momentary: Cycle freeze PIC_FREEZE_ON = 214 // Discrete: Set freeze on PIC_FREEZE_FB = 214 // Feedback: Freeze feedback MENU_RESET = 215 // Momentary: Press menu button reset MENU_INSTANT_REPLAY = 218 // Momentary: Press menu button instant replay DEVICE_COMMUNICATING = 251 // Feedback: Device online event DATA_INITIALIZED = 252 // Feedback: Data initialized event LAMP_WARMING_FB = 253 // Feedback: Lamp is warming up LAMP_COOLING_FB = 254 // Feedback: Lamp is cooling down POWER_ON = 255 // Discrete: Set lamp power state LAMP_POWER_FB = 255 // Feedback: Lamp power state feedback (** USER DEFINED CONSTANTS**) ASPECT_RATIO_16X9 = 350 ASPECT_RATIO_4X3 = 351 VP_ZOOM_IN = 352 VP_ZOOM_OUT = 353 SOURCE_VID4 = 357 LAMP_FOCUS_IN = 354 LAMP_FOCUS_OUT = 355 PC_AUTO_ADJUST = 356 SIDE_BY_SIDE = 357 (***********************************************************) (* VARIABLE DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_VARIABLE NON_VOLATILE CHAR cMsg[25] (***********************************************************) (* STARTUP CODE GOES BELOW *) (***********************************************************) DEFINE_START CREATE_BUFFER dvVP, cMsg (***********************************************************) (* STRUCTURE DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_TYPE (***********************************************************) (* MUTUALLY EXCLUSIVE DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_MUTUALLY_EXCLUSIVE (***********************************************************) (* THE EVENTS GO BELOW *) (***********************************************************) DEFINE_EVENT DATA_EVENT[dvVP] { ONLINE: { SEND_COMMAND dvVP, "'SET BAUD 19200,N,8,1'" //Sets baud rate SEND_COMMAND dvVP, "'RXON'" //starts serial port SEND_COMMAND dvVP, "'HSOFF'" //turns handshaking off ON[vdvVP,DEVICE_COMMUNICATING] } STRING: { SEND_STRING 0, "'FROM PROJECTOR: ',cMsg" //Send VP Msg to TELNET SELECT { ACTIVE(cMsg = "'(PWR!1)'"): //LAMP is ON { OFF[vdvVP,LAMP_WARMING_FB] OFF[vdvVP,LAMP_COOLING_FB] ON[vdvVP,LAMP_POWER_FB] } ACTIVE(cMsg = "'(PWR!0)'"): //LAMP is OFF { OFF[vdvVP,LAMP_WARMING_FB] OFF[vdvVP,LAMP_COOLING_FB] OFF[vdvVP,LAMP_POWER_FB] } ACTIVE(cMsg = "'(PWR!11)'"): //LAMP is WARMING { ON[vdvVP,LAMP_WARMING_FB] } ACTIVE(cMsg = "'(PWR!10)'"): //LAMP is COOLING { ON[vdvVP,LAMP_COOLING_FB] } } } OFFLINE: { OFF[vdvVP,DEVICE_COMMUNICATING] } } (**VP Command SET**) CHANNEL_EVENT[vdvVP,PWR_ON] CHANNEL_EVENT[vdvVP,PWR_OFF] CHANNEL_EVENT[vdvVP,SOURCE_VIDEO1] //Input 1 HDMI CHANNEL_EVENT[vdvVP,SOURCE_VIDEO2] //Input 1 Display Port CHANNEL_EVENT[vdvVP,MENU_ENTER] CHANNEL_EVENT[vdvVP,MENU_EXIT] CHANNEL_EVENT[vdvVP,ASPECT_RATIO_16X9] CHANNEL_EVENT[vdvVP,MENU_UP] CHANNEL_EVENT[vdvVP,MENU_LT] CHANNEL_EVENT[vdvVP,MENU_RT] CHANNEL_EVENT[vdvVP,MENU_DN] CHANNEL_EVENT[vdvVP,MENU_SELECT] { ON: { SWITCH(CHANNEL.CHANNEL) { CASE PWR_ON: SEND_STRING dvVP, "'(PWR1)',13" CASE PWR_OFF: SEND_STRING dvVP, "'(PWR0)',13" CASE SOURCE_VIDEO1: SEND_STRING dvVP, "'(SIN4) HDMI',13" CASE SOURCE_VIDEO2: SEND_STRING dvVP, "'(SIN5) DVI-D',13" CASE MENU_ENTER: SEND_STRING dvVP, "'(KEY17)',13" CASE MENU_EXIT: SEND_STRING dvVP, "'(KEY17)',13" CASE ASPECT_RATIO_16X9: SEND_STRING dvVP, "'(KEY67)',13" CASE MENU_UP: SEND_STRING dvVP, "'(KEY38)',13" CASE MENU_LT: SEND_STRING dvVP, "'(KEY39)',13" CASE MENU_RT: SEND_STRING dvVP, "'(KEY41)',13" CASE MENU_DN: SEND_STRING dvVP, "'(KEY42)',13" CASE MENU_SELECT: SEND_STRING dvVP, "'(KEY40)',13" } } } CHANNEL_EVENT[vdvVP, SIDE_BY_SIDE] { ON: { SEND_STRING dvVP, "'(PIP 1)',13" } OFF: { SEND_STRING dvVP, "'(PIP 0)',13" } } CHANNEL_EVENT[vdvVP,LAMP_FOCUS_IN] { ON: { SEND_STRING dvVP, "'(KEY5)',13" } OFF: { } } CHANNEL_EVENT[vdvVP,LAMP_FOCUS_OUT] { ON: { SEND_STRING dvVP, "'(KEY6)',13" } OFF: { } } CHANNEL_EVENT[vdvVP,VP_ZOOM_IN] { ON: { SEND_STRING dvVP, "'(KEY9)',13" } OFF: { } } CHANNEL_EVENT[vdvVP,VP_ZOOM_OUT] { ON: { SEND_STRING dvVP, "'(KEY10)',13" } OFF: { } } (***********************************************************) (* THE ACTUAL PROGRAM GOES BELOW *) (***********************************************************) DEFINE_PROGRAM { WAIT 50 { SEND_STRING dvVP, "'(PWR?)',13" (**Every 5 sec Poll Lamp**) WAIT 22 { CLEAR_BUFFER cMsg SEND_STRING dvVP, "'(LIF+LP1H?)',13" (**Every 2sec Poll Lamp**) REMOVE_STRING(cMsg, '(LIF+LP1H!', 1) LEFT_STRING(cMsg, 5) SEND_STRING vdvVP, "'LAMPTIME=',cMSG" SEND_STRING 0, "'LAMPTIME=',cMSG" } CLEAR_BUFFER cMsg } }
