NX controller IP control
jneff
I am kind of new to the NX controllers, I have been programming for 20 years, but just recently got a 3250 with an NX controller. After reading through the manual, it says that the NX controllers will use whichever RJ45 jack with the correct subnet automatically. I would like to use the ICSLAN jack if possible - Yet neither of these command below seems to create a link to a Document Camera that I already control using a serial to IP converter on our old systems. The document cameras IP does show up on the web interface under system / Manage devices / Active devices. As a test, I just sent the string expression to 0:8:0 ( Device dvIPClient ) "$01,$A0,$01,$00". Nothing. I tried the first one and then the second one - I am not 100% sure what the second is for - just that it is new with the NX controllers, When I send the string - activity lights blink on both ports, so I can't say where the data is actually going.
IP_CLIENT_OPEN(dvIPClient.Port,"'198.18.64.1'",50915,IP_TCP)
OR
SEND_COMMAND dvIPClient, "'UDPSENDTO-198.18.64.1:50915'"
The main network jack is on 255.255.255.0 and the ICSLAN jack is set to default 255,255,0.0 - I am using the first static address the manual says to use.
any ideas?
OR
any ideas?
--- 198.18.64.1 ping statistics ---
1 packets transmitted, 1 packets received, 0% packet loss
round-trip min/avg/max = 6.182/6.182/6.182 ms
So, I decided with our new installations, that it would be easier use our University network and use DNS naming conventions, since we already use part of our controllers DNS name to control other devices. Apparently you can't do that on the ICSLAN port.
Last question about this... The documentation on this command --> SEND_COMMAND dvIPClient, "'UDPSENDTO-198.18.64.1:50915'" --- Says that it only supports IP_UDP and IP_UDP_2WAY. There is no argument for that - Is it just IP_UDP_2WAY or is it defined somewhere else?
you can put other device on the icslan port but you will not be able to from the lan port. if you connect your laptop on the isclan side you will be able to talk to the device with your laptop. i recently update a system with multiple nx4200. My main processeur is connected to the client network and all other device, 2nd nx-4200, me-260 are connected on the isclan port. and it work like a charm. i have a tesira server on the ics lan side with no issue.
Also... Any use this command in code? can you explain it to me?
Danny
When I want to inject custom/manual strings, I create an obscure button event (that can be triggered by diag/emulate) and have a variable string pre-named and sized that I can edit in debug. My button event will send the string (to an expected port) when triggered. That's one way to get around the issue you describe.
