First Real Project Help
I went to Programmer 1 months ago and have slept many times since. So my knowledge has rusted shut. So I am trying to interact with a dvx and serial port 4 on it. I am controlling a Denon DN-500BD. I can't find a module so was planning on writing controls for it. My problem is I can't seem to get it to respond. Below is some information I have setup. I have even shorted pins 2 and 3 to see if I could get any information back from the port and have had zero luck. I am guessing I am missing something obvious but tired of pulling out what little hair I have. Any help would be appreciated.
Thom
dvMaster = 0:1:0 //DVX-3255HD Master
dvTP_Main = 10010:1:0 //Touch Panel
dvTP_Bluray_Serial = 10010:5:0 //Blu-ray Page
dvBluray_Serial= 5001:4:0 // This serial device
DATA_EVENT[dvBluray_Serial]
ONLINE:
SEND_COMMAND dvBluray_Serial,"'SET BAUD 9600,N,8,1'"
STRING:
LOCAL_VAR CHAR nString[25]
nString = DATA.TEXT
SEND_STRING 0, nString //sends command to telnet for debugging
BUTTON_EVENT[dvTP_Bluray_Serial,0]//This is the Touch panel push
//SWITCH(BUTTON.INPUT.CHANNEL)
IF(BUTTON.INPUT.CHANNEL==162)
idebug = 1
//SEND_COMMAND dvBluray_Serial, "'@0PCDTRYOP'"
SEND_STRING dvBluray_Serial, "'@0PCDTRYOP'"
wait(500)
send_string dvBluray_Serial, "'@0?PW'"
//trying different things but no luck
    Hi Thom,
    I think you forgot $0D at the end of the string.
    Try this:
    SEND_STRING dvBluray_Serial,"'@023PW',$0D" // power on
    SEND_STRING dvBluray_Serial,"'@02312',$0D" // power off
    Watch the Tx led on your serial port-4, does it blink? (transmit from AMX).
    Watch the Rx led on your serial port-4, does it blink? (answer from Denon).
    No, be sure you use a 1:1 cable (pin 2,3,5)
    Also if there is a "power save on" in the Denon menu, switch it off (if so power off command will always work, power on not).
    Goodluck.
    Toon.
    AWESOME!!!! I never thought I would be excited about opening a cd tray.. LOL
    Now I will search the forum on creating modules so I can build all the code for feedback....
    Thom
    no1tmorrow wrote: »
    Oh, there are lots of exciting moments coming to you - like...
    "The Lights Came ON!!!"
    "The Pool temp incremented!"
    "The CODEC Dialed OUT!!!"
    etc....
    GregGGregG Posts: 251
    And,
    "I'm sorry officer, I forgot to have them put the alarm system in test mode..."
    Thank goodness we only do Commercial!!! :-)
    PhreaKPhreaK Posts: 966
    no1tmorrow wrote: »
    Screw ups in commercial are much more fun. Usually something along the lines of...
    "I'm sorry Mr Client, I know you're trying to run a busy venue / building / Casino, that latest code dump that turned off lighting across the entire premises was unintended".
    no1tmorrow wrote: »
    The only major difference between resi and commercial is the number of phone calls and emails you get from the client per issue.
    LOL... Thanks guys. You make me feel so much more comfortable. HAHA
