ENOVA DGX 32 _ FG1060-32 why we cant control audio
msfayad
in AMX Hardware
I can't get it why we cant control audio( Vol+,Vol-,Mute, Unmute ) for DGX outputs
BCS commands for audio not working I know this line of product has audio and video on the same stream but that is really strange.
any Idea
any Idea
I Tried
'CL0O9VS+T
'CL0O9VS-T
'CL0O9VMT'
'CL0O9VUT'
'SL0O9VT'"
with no succces or feedback
This is from the BCS manual.
You are not alone in struggling with the manual for the integrated switchers (DVX / DGX) the manuals are convoluted and seemingly mixed up. I really wish they'd just make one big manual with everything in it. That way you wouldn't have to deal with trying to find which PDF file you need. For example: on the AIE card, the DGX/ NX series manual references its BCS commands by saying to get them from the devices manual. I've looked at everything to do with AIE or any audio card for that matter and there is nothing referrencing volume or commands.
There is no audio level control capability for DGX outputs.
You may well be correct on that. I could not find one. I'd give the folks at Tech Support a call and ask what's up with it.
Ina ll the cases where I've done a system with the audio break out cards there was a separate DSP routing audio. I checked all the code I have for the DGX and didn't find the command. I'm betting there is one but the manual is lost in the website shuffle that is AMX.
With you referring to the FG1060-32, you are talking about the DGX32 (not the DGX100 series) which does not support the newer cards.
The recommended solution if you want to have audio breakaway is to reserve a single matrix output for the audio switched as required in code. This unfortunately makes it hard to utilise manual control off the front panel where it adds a chance for a user to forget to switch the audio correctly or send the wrong source.
In the DGX32, as you can only install one card for each of the input and output you only get access to the first 16 channels of each, inputs & outputs 17-32 have no access via the AIE card. for the other size frames (8 & 16) you get access to all audio feeds and the DGX64 has access to the first 32 inputs & outputs.
I'd call tech support.
If you take a look through the manuals you will see that there is actually no audio control at all on the standard AIE cards that you have there. DSP style controls of the audio signals was only revealed to us last year at the AU Dev Conference in the DGX100 range - I tried to get an answer on whether it could be possible to bring the features into the DGX8/16/32 range but not without changing nearly everything!!!
You need to be aware that there is now 3 different platforms within the DGX range -
FG1058 - DGX8/16/32 with a NI processor (Standard AIE cards only)
FG1060 - DGX8/16/32/64 the previous version frame with a NX processor card (Standard AIE cards only)
FG1061 - DGX800/1600/3200/6400 This version takes both the standard AIE card as well as the ASB card that includes a DSP which can do what you are asking for.
