Home AMX Resource Management Suite Software
RMS with Multiple Rooms and Single Processor
Hi All,
Does anyone know the cleanest way to handle multiple rooms on a single NX Processor?
Mainly to do with System Power, Source Usage, Help Request and Control Actions. The physical device side of things is straight forward by using the RMS Web UI to move them into their locations, but because with System Power etc are kind of Client Gateway dependant it is a little bit more difficult to keep them separate.
Any ideas would be great!!
Cheers!
  • AvargasAvargas Posts: 57
    Hi!
    You can use a system virtual device for each room, that manages the control and source usage of each room in particular. In the first deployment you have to move the virtual devices also, like you would do with the physical devices.
    Don't know if I explained myself. Hope this could help.
    Regards,
