What happened to my "Build Active System"?
Anyone have any ideas? I was removing some old code out of my program. Now the Build Active System (tool and drop down) are grayed out. If I open another project the icon comes back. Can't quite figure out what happened. Didn't remove anything important. Can send the program to the master just fine. Corrupt?
    Check to see if your man source file is "Set To Master"
  • Thanks for the quick reply Eric. I just got it. Somehow it wasn't selected as my active system. Don't know how that happened? If anyone else runs into this...right click on your system folder in the work space window, and select "set as active system". Wheew!!!
    That's actually what I meant. My bad. Good to hear you're up and running.
