TAB in message field?
This is just a small request but is there any way that we can enable tabbing while writing out posts. It gets pretty frustrating when writing out pseudo-code not to mention nearly impossible to read in a final post with braces lined up the way they are.
If you want to post some programming source code, or perhaps some ASCII art, which would require a non-proportional font, you can use the [ code ] tag to achieve this (You have to get rid of the spaces in the brackets). For example:
<script language="Javascript"> <!-- alert("Hello world!"); //--> </script>......... .'------.' | Plug and Play | .-----. | | | | | | | __| | | | |;. _______________ / |*`-----'.|.' `; // / `---------' .;' // /| / .''''////////;' // |=| .../ ######### /;/ //| |/ / / ######### // //|| / `-----------' // || /________________________________//| || `--------------------------------' | || : | || | || |__LL__|| || | || : | || | || | || `""' n | || `""' | || M | || | || | || | || `""' `""' MasterMindJust had to try this.
