DVX-3255 Ethernet port config
Silly question.
Is there any way to set the ethernet port on the DVX-3255 to manual 100/full instead of auto? I can't seem to find the command or the place on the web configuration to do so.
Thank you
    viningvining Posts: 4,368
    Did you try telnet?
    feddxfeddx Posts: 175
    vining wrote: »
    Did you try telnet?
    ...and the telnet command to set the device to 100/full duplex are?
    Odd they are not in the manual or the programming guide that I can see for the 3255. And on a general listing with the '?' query, I cannot see a command either.
    Has this been eliminated with the NX processor?
    I could just be missing it, but I'm not seeing it.
    Don't know if they've been eliminated in the NX or not, just assumed they'd be there like NI. I'll take a look at mine when I return and see, haven't really spent much time going through their features to see what might be different.
    Nope, don't see that option anymore in the NX controller.
    PhreaKPhreaK Posts: 966
    feddx wrote: »
    set ethernet mode 100 full
    If you're ever stuck for the commands from the telnet/SSH prompt just type `help`
    PhreaK wrote: »
    Unknown Command 'set ethernet mode 100 full'
    No joy on NX controllers, ? / help doesn't list anything similar to what the NI controller did for this option.
    Ah, completely missed the NX controller part.
    GregGGregG Posts: 251
    if you can force the switch port you are plugging into to 100/half, then autonegotiation on the amx side should fall back to match that.
    https://en.wikipedia.org/wiki/Duplex_mismatch#Duplex_mismatch_due_to_autonegotiation
