Best practice question (migrate from ni to nx)
Hi,
I'm currently updating an ni system to a nx-4200. I have 2 questions regarding code structure.
I presume the ni program was originally an accent because a lot of work were done in define program ( feedback, serial parsing) and no define_function only define_call.
1). I'm creating ? timeline_event to provide feedback. It is better to use everything in the timeline_event with a timeline. S?quence or create a function feedback() and recall it inside the timeline. Prior i was using my feedback() in define_program but with the nx serie is no more recommand?s to use
2) do i still using define_call or replace them with define_fonction.
Thanks for your input.
    Functionally speaking I don't think it matters one way or another whether you put all the feedback code right in the Timelin_event or pass it out to a function. Since Netlinx is not a multi-thread language you can almost think of a function (or call for that matter) as a GOTO. I still do it as a matter of principle as I like to keep my code clean and I like to keep work-a-day code in my functions. That way there's typically only one place I need to go to make global changes to a section of code that might be hit by several events other than just a FB timeline. (For example if a TP comes online, I might want to update the same FB set)
    I actually don't use define_call myself as it's left over from olden days of yore... But I think it still works just fine in the NX series procs.
    You also might want to take a look at the modules being used. There may be newer ones.
  • GregGGregG Posts: 251
    Personally, I like to put multiple event blocks for the same feedback timeline around in the code, near where they apply, like:
    Button_Event[dvTP, BTN_DEVICE1_POWER]
        Push: SendDevice1PowerOn()
    Timeline_Event[TL_FEEDBACK]
        [dvTP, BTN_DEVICE1_POWER] = nDevice1PowerOn
    Button_Event[dvTP, BTN_DEVICE2_POWER]
        Push: SendDevice2PowerOn()
        [dvTP, BTN_DEVICE2_POWER] = nDevice2PowerOn
  • RaphayoRaphayo Posts: 111
    Correct me if i'm wrong, but i think the difference between define_call & Define_function is that the code line wait the completion of define_call before to continue instead of the define_function the code continue during the process of the function. Am I Correct?
    For the TP Feedback, it will be better to have a timeline_event for everyTP who will be activate if the tp goes online.
    GregG approach for timeline is very easy to read, button_event follow by timeline_event.
    Raphayo wrote: »
    Nope, they work the same. Here's a little test program to illustrate.
    PROGRAM_NAME='test'
    vdv_MyDevice    =    34001:01:1
    define_function fn_My_Function(){
        stack_var integer fun_loop;
        for(fun_loop=5;fun_loop;fun_loop--){
            send_string 0," 'fun_loop=',itoa(fun_loop)"
            }// for
        send_string 0, 'Fun_Step_2';
        send_string 0, 'Fun_Step_3';
        } // def_fun
    define_call 'My_Call'{
        stack_var integer call_loop;
        for(call_loop=5;call_loop;call_loop--){
            send_string 0," 'call_loop=',itoa(call_loop)";
            } // for
        send_string 0, 'Call_Step_2';
        send_string 0, 'Call_Step_3';
        } // def_call
    button_event[vdv_MyDevice,1]{
        push:{
            send_string 0, 'Before the Call';
            call 'My_Call'
            send_string 0, 'After the Call';
        } //b_e
    button_event[vdv_MyDevice,2]{
        push:{
            send_string 0, 'Before the Function';
            fn_My_Function();
            send_string 0, 'After the Function';
        } //b_e
    and the result
    The Call
    >(0000057955) Before the Call
    (0000057956) call_loop=5
    (0000057957) call_loop=4
    (0000057957) call_loop=3
    (0000057957) call_loop=2
    (0000057957) call_loop=1
    (0000057958) Call_Step_2
    (0000057958) Call_Step_3
    (0000057958) After the Call
    the function
    (0000072100) Before the Function
    (0000072101) fun_loop=5
    (0000072101) fun_loop=4
    (0000072101) fun_loop=3
    (0000072102) fun_loop=2
    (0000072102) fun_loop=1
    (0000072102) Fun_Step_2
    (0000072102) Fun_Step_3
    (0000072102) After the Function
    Here again, netlinx is not multi-thread.
  • What I do usually, I don't use define_program for any of the feedback code as much as I can, because the feedback state will change when a device (the controlled device) will send a message notifying that, which will be received in the code through data_event (if modules are not used) or through channel_event, level_event or data_event (if module is used)
    so what I do I update my buttons in these events, which will make the button state changes only when the device send a notification about that, which make very sense, why should I keep updating the touch panel every one second, personally I treat this as overload on the master and network
    I hope that this could help
  • GregG wrote: »
    I love the organization of doing it that way. Is there any real-world drawback to having it spread out everywhere like that?
    I can say that I have never noticed any performance impact from separating it compared to keeping it all in a single event. I'm not sure how the netlinx compiler deals with duplicates of the same event internally.
    However, I also don't do very much feedback in timelines of any sort, due to the performance effects of constantly updating feedback for things that have not changed.
  • mushmush Posts: 288
    GregG wrote: »
    This is my observation and practice also.
    DEFINE_PROGRAM was actually deprecated in NetLinx but was retained to allow easy transition from Axcess. DEFINE_CALLS and some other things were also retained for the same reason.
