Compiler directives in IF statements
So I guess I am confused with compiler directives, specifically #DEFINE. I have a couple of #DEFINE's in some IF statements and the point is to only define them if a particular variable is true....simple enough. However it seems like at least with #DEFINE's that it runs that line no matter what regardless if it is in an IF statement and regardless if the condition is true or false. Is this correct? I have not done a proof of concept just slimming it down but I am fairly sure that this is happening.
    MLaletasMLaletas Posts: 226
    So I guess I just am missunderstanding how #DEFINE works. Just did a proof of concept with the following code and results
    PROGRAM_NAME='Directive Test'
    (*  FILE_LAST_MODIFIED_ON: 03/01/2016  AT: 16:18:44        *)
    dvMaster        = 0:1:0
    vdvTest            = 33001:1:0
    DEFINE_CONSTANT
    DEFINE_TYPE
    INTEGER nTest
    DEFINE_LATCHING
    DEFINE_MUTUALLY_EXCLUSIVE
    CHANNEL_EVENT[vdvTest,1]
        ON:
        IF( nTest )
            #DEFINE DEFINE_ENABLED
        #IF_DEFINED DEFINE_ENABLED
            SEND_STRING 0,"'nTest: ',ITOA( nTest )"
            SEND_STRING 0,"'Define enabled went through'"
        #END_IF
    DEFINE_PROGRAM
    Results:
    Line      1 (16:19:52)::  nTest: 1
    Line      2 (16:19:52)::  Define enabled went through
    Line      3 (16:19:59)::  nTest: 0
    Line      4 (16:19:59)::  Define enabled went through
    Compiler Directives only work at compile time - NOT RUNTIME.
    What are you trying to accomplish?
    I think the way you have this coded the DEFINE_ENABLED will always be defined.
    The Compiler does not evaluate IF ( nTest ) at Compile time.
    Oh compile time, I must have read over that. So this will absolutely not work with what I am trying to do. Thank you donachiue. What I am trying to achieve is to read in a file that will designate what type of device it is, for example a Samsung display.
    #IF_DEFINED DISP1_SAMSUNG
    DEFINE_MODULE 'Samsung display' samsung1( dvdisp1, vdvdisp1 )
    #END_IF
    Now obviously that will not work, I have to rethink how I am going to approach this.
    GregGGregG Posts: 251
    I use a meta-function and set a variable to indicate what type each monitor is, like this:
    Define_Function MonitorFunction(Integer nMonitor, Integer nInput)
        Switch(nMonitorProtocol[nMonitor])
            Case MONITOR_TYPE_NEC:
                NECFunction(nMonitor,nInput)
            Case MONITOR_TYPE_PLANAR:
                PlanarFunction(nMonitor,nInput)
            Case MONITOR_TYPE_PANASONIC:
                PanasonicFunction(nMonitor,nInput)
            Case MONITOR_TYPE_SAMSUNG_HOTEL:
                SamsungHotelFunction(nMonitor, nInput)
            Case MONITOR_TYPE_PANASONIC_NEW:
                PanasonicNewFunction(nMonitor, nInput)
            Case MONITOR_TYPE_VIEWSONIC:
                ViewsonicFunction(nMonitor, nInput)
            Case MONITOR_TYPE_SHARP_SPACES_AFTER:
            Case MONITOR_TYPE_SHARP_SPACES_BEFORE:
                SharpFunction(nMonitor,nInput,nMonitorProtocol[nMonitor])
            Default: { Send_String 0,'Unknown monitor type'}
    Of course, this means I can't use display modules... but no real loss there.
    Thats not bad, I would have to convert all my modules to use that kind of functionality but thats definitely an option, btw i like you naming for the Sharp display :)
    I've done this by defining multiple modules for a given display (or other device) each with their own virtual device, then another virtual device that the program interacts with and use an array of devices with a flag to control which one is active.
    So instead of:
    SEND_COMMAND vdvDISPLAY1, "'POWER ON',$0D"
    You would have:
    SEND_COMMAND vdvDISPLAY1[nACTIVE_DISPLAY], "'POWER ON',$0D"
    And so on. For DATA_EVENTS from the devices, you would do something like:
    DATA_EVENT[vdvDISPLAY1]
             STRING:
                     IF(GET_LAST(vdvDISPLAY1) == nACTIVE_DISPLAY)
                             //DO WHATEVER FEEDBACK HANDLING FROM DISPLAY1
    It makes for a bunch of code but makes sense if you have a bunch of identical rooms that vary by display model or type of playback device for instance.
    Here's another way you might accomplish your goal, without converting your modules over. It does not 'read' from a file that is loaded to the disc on chip, but may provide the functionality you are looking for.
    Have a config.axi file with your #define statements:
    #define Display_Samsung
    #define Bluray_Oppo
    #define Switcher_ExtronSIS
    etc, etc.....
    In your main program file, call this axi file first. Then use compiler directives to instantiate your modules if and only if the specific keyword is defined:
    #if_defined Display_Samsung
    define_module 'Samsung Display'
    #end_if
    Hope this helps,
    erik
