DGX 8 can't access web control after upgrade
I upgraded the master to 1.4.72 and now can't access the web control. It is asking for id and password, i never enabled them before, Put in defaults and says invalid. I put in administrator for id and various passwords I would have used and none work, including the default password.
Anyone able to help with this?
    MLaletasMLaletas Posts: 226
    the new firmware enables security, the default is administrator and password. Did you change the security login previously?
    gsmithgsmith Posts: 59
    The default is administrator/password. Also you may need to try different browsers. The new web interface uses HTML5/Web Sockets and not all browser versions support this.
