Home AMX Technical Discussion
Best way to Control Windows 7 Media Center
I wondered if someone could offer me some advice on the best method for controlling Windows 7 Media Center?
Thanks in advance,
Steve
    If you're brave, you could try the MCS software from Autonomic Controls.
  • MCE controller software
    I use MCE controller at home on a Win 7 media centre - a freeware program by Kindle systems. Basically, after you install this program on your medie centre Win 7 or Win XP machine, stick it into the startup folder.
    Configure the port on the PC side, and then program in an IP device into the NI (including the port number).
    The list of commands is included in the docs, and its real easy to use. You send it a string ( 'play') and it then translates this and sends the keyboard shortcut to the medie centre.
    you can download it at
    http://www.kindel.com/products/mcecontroller/
    Hope this helps, but I'll post sample code if you want it.
    Regards,
    Andrew
  • sijonessijones Posts: 16
    Thanks Andew! I'll give it a go.
    Kind regards,
    Steve
  • udiudi Posts: 107
    How can I do command CTRL + O , meaning CTRL key is holed when i press the letter o letter on the keyboard?
    udi wrote: »
    It, like everything else you send, is nothing more than a hex char (ascii) I think cntr-c is $03.
    https://en.wikipedia.org/wiki/ASCII
  • udiudi Posts: 107
    i meant with the MCE controller how can i sent it? it doesn't work according to what you said
  • DraugarDraugar Posts: 27
    udi wrote: »
    http://mcec.codeplex.com/documentation "For example, the following causes a Ctrl-P to be sent to the foreground window, and if that window is Media Center, the My Pictures page appears:"
    <SendInput Cmd="mypictures" vk="73" Shift="false" Ctrl="true" Alt="false" /> "(The VK code or 'P' is 73 decimal)."
  • udiudi Posts: 107
    but what command i need to send on the netlinx?
    Not current thread but this link should help
    http://www.physics.udel.edu/~watson/scen103/ascii.html
