Samsung TV on RS-232
locknar
I have two Samsung 65UNj Tv's on the exlink RS-232. Both of the TV's turn on (command 08-22-00-00-00-01-d4) so I know I have cabling correct, port address etc, but neither TV turns off. Tried both the 08-22-00-00-00-02-d5 and the 00-d6 power toggle). How can I have control for one command and not the other? Even tried putting the on into the off button on the Tp to make sure I hadn't made a simple mistake in the TP.
Made sure there was no source connected, swapped RS-232 ports between left and right but always only turn on, not turn off.
I also have a $13 tacked on the end of the power on command out of mostly superstition - it apparently once helped wake the tv up more reliably for someone (and it doesn't seem to hurt anything).
Power Toggle = "$08,$22,$00,$00,$00,$00,$D6"
Power Off = "$08,$22,$00,$00,$00,$01,$D5"
Power On = "$08,$22,$00,$00,$00,$02,$D4"
This line of Samsungs are probably the worst displays I've worked with on many fronts in over a decade.
Thank you.
I don't know who authored it though. It's worked well for me so far.
