Presentation timer on a CV12 with an NI Series Master
dmenke
I realize this may be a simple thing for more experienced programmers, and yes I have scoured the forums, but not found what I am looking for. My client has asked for a countup timer that shows the amount of time that has passed since the start button has been pressed, for timing presentations and such. I am aware that the WAIT command is notoriously inaccurate for measuring time consistently, and the TIMELINE command seems Greek. A fellow Linux user suggested sampling the system clock, and maths, going so far to give me examples in JAVA and C++. More Greek.
So far, I have managed to put together a usable interface, but am failing miserably at the code to drive it. Can anyone throw me a bone with some code, and possibly an explination of TIMELINE if that is how you do it?
Doug
Doug
I would essentially (obviously) create a stop watch-type thing.
I upon the start button - I would start a repeating timeline that ticks away each second. I would create a integer variable called MyTimer or whatever that starts at 1 and increments each fire of the timeline.
The pause button would just pause/kill the timeline. The RESET button would just set the counter time back to zero.
To display the time on the touch panel, I'd make a little routine/function that converts the integer decimal number of seconds since start to minutes/seconds.
It looks like this:
nMins=MyTijmer/60
nSeconds= MyTimer-(MyTijmer*60)
(there are quite a few ways to do this - this is basically just to explain the principle.
Then convert the integers nMins and nSeconds to the text you want. and then send the whole text to a variable text button on the TP.
You'll have to do a little bit of logic to deal with leading zeros and so forth.
ex: if the nMins=5 and nSeconds=8
if you just do something like send_string MyTP," 'TEXT101-',itoa(nMins),':',itoa(nSeconds)";
you'll get 5:8 on the TP instead of 5:08 So, I'd do something like
if(nSecond=0){MyString='00';}
else if(nSecond<10){ MyString=" '0',itoa(nSeconds);
else {MyString="itoa(nSeconds)";
You will need to create a long variable to use as the timeline ID, and a long array to use as the times the timeline will fire. Something like this:
When it comes time to start the timer, timeline_create will start the timeline events firing at the specified times: Here, it doesn't matter if we use timeline_absolute or timeline_relative, since we only have one time in our array, but if we had multiple items in the array, this would determine how they fired.
Timeline_repeat will keep the timeline running until we stop it.
When it comes time to stop the timer, use timeline_kill
To perform a task when the time has elapsed, use a timeline event:
