Bad duet module?
Draugar
Hi,
I have an issue with the Epson_Video_Projector_EB-G7000W_1.0.0 module, it will not start. I have tried replacing it wt the EB-1970W which works.
A REINIG gives:
Line 592 (12:00:06):: DDD.physicalDeviceOffline: 5001:1:0 is offline
Line 593 (12:00:06):: (Reader=749028432 writer=743654480)- CMessagePipe::Max = 50
Line 594 (12:00:10):: DDD.handleTimerEvent: dpd didn't exist
(Note: I am going to create 10 virtual devices to control 10 physical projectors, is there anywhere this will be a !#@$ idea? The other module worked, both XDD.)
A REINIG gives:
DEFINE_DEVICE dvTPMain = 10001:1:0 // MSD-701L dvProj1 = 5001:1:0 dvProj2 = 5001:2:0 dvProj3 = 5001:3:0 dvProj4 = 5001:4:0 dvProj5 = 10101:1:0 // EXB1 dvProj6 = 10101:2:0 // EXB1 dvProj7 = 10102:1:0 // EXB2 dvProj8 = 10102:2:0 // EXB2 dvProj9 = 10103:1:0 // EXB3 dvProj10 = 10103:2:0 // EXB3 vdvProj1 = 41001:1:0 vdvProj2 = 41002:1:0 vdvProj3 = 41003:1:0 vdvProj4 = 41004:1:0 vdvProj5 = 41005:1:0 vdvProj6 = 41006:1:0 vdvProj7 = 41007:1:0 vdvProj8 = 41008:1:0 vdvProj9 = 41009:1:0 vdvProj10 = 41010:1:0 #INCLUDE 'SNAPI.AXI' DEFINE_FUNCTION fnPulse(INTEGER nChannel) { PULSE [vdvProj1,nChannel] PULSE [vdvProj2,nChannel] PULSE [vdvProj3,nChannel] PULSE [vdvProj4,nChannel] PULSE [vdvProj5,nChannel] PULSE [vdvProj6,nChannel] PULSE [vdvProj7,nChannel] PULSE [vdvProj8,nChannel] PULSE [vdvProj9,nChannel] PULSE [vdvProj10,nChannel] } DEFINE_FUNCTION fnSetInput() { SEND_COMMAND vdvProj1,"'INPUT-HDMI'" SEND_COMMAND vdvProj2,"'INPUT-HDMI'" SEND_COMMAND vdvProj3,"'INPUT-HDMI'" SEND_COMMAND vdvProj4,"'INPUT-HDMI'" SEND_COMMAND vdvProj5,"'INPUT-HDMI'" SEND_COMMAND vdvProj6,"'INPUT-HDMI'" SEND_COMMAND vdvProj7,"'INPUT-HDMI'" SEND_COMMAND vdvProj8,"'INPUT-HDMI'" SEND_COMMAND vdvProj9,"'INPUT-HDMI'" SEND_COMMAND vdvProj10,"'INPUT-HDMI'" } DEFINE_START DEFINE_MODULE 'DeviceDriverEngine' Proj1 (vdvProj1 , dvProj1, projXDD) DEFINE_MODULE 'DeviceDriverEngine' Proj2 (vdvProj2 , dvProj2, projXDD) DEFINE_MODULE 'DeviceDriverEngine' Proj3 (vdvProj3 , dvProj3, projXDD) DEFINE_MODULE 'DeviceDriverEngine' Proj4 (vdvProj4 , dvProj4, projXDD) DEFINE_MODULE 'DeviceDriverEngine' Proj5 (vdvProj5 , dvProj5, projXDD) DEFINE_MODULE 'DeviceDriverEngine' Proj6 (vdvProj6 , dvProj6, projXDD) DEFINE_MODULE 'DeviceDriverEngine' Proj7 (vdvProj7 , dvProj7, projXDD) DEFINE_MODULE 'DeviceDriverEngine' Proj8 (vdvProj8 , dvProj8, projXDD) DEFINE_MODULE 'DeviceDriverEngine' Proj9 (vdvProj9 , dvProj9, projXDD) DEFINE_MODULE 'DeviceDriverEngine' Proj10 (vdvProj10 , dvProj10,projXDD) BUTTON_EVENT[dvTPMain,0] { PUSH: { SWITCH(button.input.channel) { CASE 1: { PULSE[vdvProj1,27] IF(!nProjStatus) { nProjStatus = 1 TIMELINE_CREATE(WaitTL, TL_CT, 1,TIMELINE_RELATIVE, TIMELINE_REPEAT) //timer page on touchpanel } fnPulse(PWR_ON) WAIT ProjTimer fnSetInput() } CASE 2: { PULSE[vdvProj1,28] IF(nProjStatus) { nProjStatus = 0 TIMELINE_CREATE(WaitTL, TL_CT, 1,TIMELINE_RELATIVE, TIMELINE_REPEAT) //timer page on touchpanel } fnPulse(PWR_OFF) } CASE 3: { SEND_COMMAND dvTPMain,"'@PPN-TL_6;Meny'" TIMELINE_CREATE(StatusTL, TL_CT2, 1,TIMELINE_RELATIVE, TIMELINE_REPEAT) //timer page on touchpanel } CASE 4: { TIMELINE_KILL(StatusTL) } } } }
I did try to amp up the duet memory to 128M with no results.
I ended up skipping the cool part (having a small service menu with lamp counters etc.), and just sent the hex to each projector instead. Sorry for late reply, butthanks for answers
