DGX/DVX with DXLink, undocumented Commands!
Sometimes I do not like AMX ...
Reason:
Many commands are not fully documented, so i found the following undocumented commands:
Command: ?CONFIG-dxlinktxdetails,<port>
Example: send_command 5002:1:0, '?CONFIG-dxlinktxdetails,2'
Data : CONFIG-dxlinktxdetails,2,255,{2,149,v1.8.26;151,DISABLE;1 57,[1\,0\,1\,0];175,OFF;183,192.168.4.184;184,255.255.255.0;185,6111;186,00:60:9F:9F:8A:45;182,;226,12;}
In this case, i found the DXLink-TX-Sender with Address 6111 on Input Port 2!
With this info, in case of mobile media transmitters, i can programming my sources dynamic
Command: ?CONFIG-videoindxlink,<port>
Example: send_command 5002:3:0, '?CONFIG-videoindxlink,3'
Data : CONFIG-videoindxlink,3,255,{3,19,HDMI;21,1920x1080p\,60;2 2,ALL RESOLUTIONS;25,1920X1080P\,60;30,ENABLE;80,BD 2;144,DXLINK MULTIFORMAT TX;146,2;147,BIDIRECTIONAL;102,ENABLE;139,0;140,0; 141,0;173,FALSE;175,OFF
Command: ?CONFIG-videooutdxlink,<port>
Example: send_command 5002:3:0, '?CONFIG-videooutdxlink,3'
Data : CONFIG-videooutdxlink,3,255,{1,1,AUTO;2,1920x1080\,60\,DS ;3,MAINTAIN;4,DISABLE;5,TOP LEFT;6,BLACK;7,OFF;8,BLUE;18,DISABLE;104,Raum 1;9,50;10,50;16,DISABLE;219,ENABLE;220,10;145,DXLI NK HDMI RX;148,BIDIRECTION
Command: ?DXLINKIN_QUALITY
Example: send_command 5002:3:0, '?DXLINKIN_QUALITY'
Data : DXLINKOUT_QUALITY--19
Command: ?ENDPOINT_TX_SOURCE
Example: send_command 5002:3:0, '?ENDPOINT_TX_SOURCE'
Data : ENDPOINT_TX_SOURCE-2
And whats that?!? (always 2 for all ports)
etc., etc.
(Sorry my bad english ...)
Reason:
etc., etc.
Query type of inputs & outputs:
?STACK_INFO
Response:
STACK_INFO,255,vidin[DX,DX,DX,DX,DX,DX,DX,DX,DX,DX,DX,DX,DX,DX,DX,DX,HD MI,HDMI,HDMI,HDMI,HDMI,HDMI,HDMI,HDMI,NULL,NULL,NU LL,NULL,NULL,NULL,NULL,NULL];vidout[DX,DX,DX,DX,DX,DX,DX,DX,NULL,NULL,NULL,NULL,NULL,N ULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,N ULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL];audin[DI,DI,DI,DI,DI,DI,DI,DI,DI,DI,DI,DI,DI,DI,DI,DI,DI ,DI,DI,DI,DI,DI,DI,DI,NULL,NULL,NULL,NULL,NULL,NUL L,NULL,NULL];audout[DI,DI,DI,DI,DI,DI,DI,DI,NULL,NULL,NULL,NULL,NULL,N ULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,N ULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL];
Unkwnown:
?CONFIG-switchfabricvideo,1..32
Respone:
CONFIG-switchfabricvideo,1..32,255,{1,95,3;}{2,95,0;}{3,9 5,3;}{4,95,3;}{5,95,3;}{6,95,3;}{7,95,3;}{8,95,3;} {9,95,0;}{10,95,0;}{11,95,0;}{12,95,0;}{13,95,0;}{ 14,95,0;}{15,95,0;}{16,95,0;}{17,95,0;}{18,95,0;}{ 19,95,0;}{20,95,0;}{21,95,0;}{22,95,0;}{23,95,0;}{ 24,95,0;}{25,95,0;}{26,95,0;}{27,95,0;}{28,95,0;}{ 29,95,0;}{30,95,0;}{31,95,0;}{32,95,0;}
Unkwnown:
?CONFIG-switchfabricaudio,1..32
Respone:
CONFIG-switchfabricaudio,1..32,255,{1,96,0;}{2,96,0;}{3,9 6,8;}{4,96,8;}{5,96,10;}{6,96,22;}{7,96,0;}{8,96,1 6;}{9,96,1;}{10,96,1;}{11,96,1;}{12,96,1;}{13,96,1 ;}{14,96,1;}{15,96,1;}{16,96,1;}{17,96,1;}{18,96,1 ;}{19,96,1;}{20,96,1;}{21,96,1;}{22,96,1;}{23,96,1 ;}{24,96,1;}{25,96,1;}{26,96,1;}{27,96,1;}{28,96,1 ;}{29,96,1;}{30,96,1;}{31,96,1;}{32,96,1;}
Quallity of DXLink (input / output)
?DXLINKIN_QUALITY
?DXLINKOUT_QUALITY
Response:
DXLINKIN_QUALITY--19
Query DX Link Details
?CONFIG-dxlinktxdetails,3
Response:
CONFIG-dxlinktxdetails,3,255,{3,149,v1.8.26;151,DISABLE;1 57,[1\,0\,1\,0];175,OFF;183,192.168.4.153;184,255.255.255.0;185,6 102;186,00:60:9F:9F:7D:75;182,Raum 2 / Bodendose 1;226,12;}
Structure: (dxlinktxdetails) => {} [Port], (3)
[ID-149], [Firmware] , [v1.8.26]
[ID-151], [AUTO_SETUP] , (DISABLE)
[ID-157], [Dip-Switch] , ([1\,0\,1\,0])
[ID-175], [???], (OFF)
[ID-183], [IP] , (192.168.4.153)
[ID-184], [Subnetz] , (255.255.255.0)
[ID-185], [DeviceNr] (6102)
[ID-186], [MAC-Adresse], (00:60:9F:9F:7D:75)
[ID-182], [FriendlyName], (Friendly name configured on DxLink-Box)
[ID-226], [System], (12)
