BSS BLU-103 VoIP
davidg
Hey All!
Does anyone have any experience controlling the BSS BLU-103, specifically the VoIP dialing functionality?
I have to adjust the stock BSS Include file to work with VoIP (as currently it only supports the analog dialer) and am having tons of difficulty working with and understanding the BSS Include which is not very user-friendly at all. Volume controls are fine but dialing is giving me headaches! To exacerbate the issue, I don't have a VoIP server to test against so most of what I'm doing is just conjecture at this point.
Any assistance would be greatly appreciated!
On their message you could read: 1) It's not perfect yet, 2) The help file is not updated for the .axi; 3) Most everything everything needed on the VoIP card can be controlled from there, 4) The strings for the speed dial name/number are not finished in axi yet, 5) Also, when subscribing to the Caller ID field on the VoIP card, it acts like a meter and will continually send a response, maybe you should treat that.
As far as I could test it, it is working well. Understanding the module (with the help file and a good read on the netlinx files) is worth a try and will save you time. Since this was sent by their support I am sharing here.
Feel free to download it. It is very much a work in progress so if you do try it out PLEASE let me know if you find any errors or have any suggestions for improvement. I will work on sprucing up the documentation soon, but for now there is a basic spreadsheet with a list of send_commands that can be used and an example program. Disclaimer: the touch panels are awful as I was not going for finesse, just for something I could test really quickly.
http://www.beardsbytes.com/downloads.html
