ONKYO TX-NR636 control
WLB Automation
Hi,
Need some help with a ONKYO TX-NR636.
We replaced the old TX-NR609 with the new 636, but we cannot control the unit over TCP/IP. The code worked fine with the older model and the local ONKYO supplier confirmed that the protocols have not changed.
I am connecting to the unit as I can see the strings coming in when I make changes on the device via the remote.
Does anybody know if the protocol has changed?
Thanks.
Thanks.
Not that I can see. Only setting that I could find was one that said Network standby and I tried in the on and off position.
I have also noticed that if I send it commands (the same commands as with the NR609) the unit will freeze and I have to do a factory reset. I have tried static and DHCP address but no luck. I think that the problem lies with the unit. I have sent it in twice now to the local agents and it comes back that there is no problem with the amp, but when I asked them if the TCP/IP communication was tested as I asked, the answer was no every time. I don't think that they know how to test the communication on the amp and that they just test the unit for basic functions.
