AMX EXB-IRS4
jkranz286
Good morning,
I have an EXB-IRS4 bound to my system. I've tried using it at start address 31021:1:1 and 5101:1:1. When I send the IRL files to this device it seems to only accept them on 5101:1:1 and not the other ports. I am not able to control any of the IR devices. What am I missing?
Oh, I think I know what's going on as I have ran into this myself. The deal is this - when you send the files you must not send them to all the ports at once. What's happening is the first port gets the file. Then the device hangs a bit while it reboots or reinits or whatever it does. so, it's not available to receive the next file when your computer tries to do so. Try sending each port individually. Send port one. Test it for pulses and so forth. Then send port 2. wash rinse repeat.
