Polycom Group 310?
davidg
Hi Everyone!
Does anyone have any experience controlling the Polycom Group 310 codec via RS-232? If so, were you able to get it working with the Duet module that's posted on the AMX site? I'm trying to use the 'Polycom_RealPresence300_Comm_dr1_0_0.jar' and getting no communication whatsoever even after going through normal troubleshooting steps. I'm wondering whether this module works with the 310 at all...or only the 300. And, if not, is there even one out there that works with the 310...
Have used the module for the 500 series successfully in the past and I'm spinning my wheels wondering what the issue could be. Can't find any codec settings that would be problematic either.
Any insight or experience controlling this codec that you guys might have would be much appreciated!
I've done a bunch of group series(300,310,500 and 700) all with the same protocol over serial. The techs ALWAYS mess up the 8-pin mini DIN. I've got a bunch in my bag for that reason.
here's a pinout
Thanks Zach (and everyone)! So just to be clear, you used the Duet module for the 310? I'm sure at the end of the day it's going to end up being wiring but just want to be validated that someone out there has been successful with that module...
In my case - no. Not that specific model.
And, for the sake of discussion: there is a RealPresence 300 moudle on the AMX site.
No Sir - the protocol is straightforward,though. You can find it in the integration reference manual on polycom's support website.(rpg_irm.pdf).
Yeah, that's the one I'm using. First time I've used this one though. I've had good luck with the 500 series module in the past (although I was also working with a 500 series codec). I'm considering, if the protocol is identical between the series', just trying out the 500 series module. Could be that the 300 series module has issues...
Thanks again guys! Much appreciated as always...
Ha! You beat me to this by about a minute! I was just reading my notes on a project where I had a 500 module with a 300 box. sure enough, in my notes was a little line saying, "hmmm... couldn't get the 300 module to respond. tried the 500 and it works. Note: report this to AMX TS"
Sorry, I should have remembered that. My poor old memory is getting too full...
