NX Firmware 1.5.78 - Download Problem
Anyone else tried to download the newest firmware release, 1.5.78, for the NX processors and if so, has anyone been able to successfully download the kit? I have tried numerous times on different platforms with different browsers but all attempts to download fail. The AMX site indicates the file is 166MB in size but the downloads reach the 163MB point and then fail every time. Just wanted to check to see if anyone has tried the download and if so, whether the download was successful before I check with AMX Tech Support.
    Did you try clean disk before loading the FW or just load a blank program and then the FW, might help since it sounds like your running out of space.
  • I can't download the firmware from the AMX web site onto the local PC. Loading to an NX master is not the issue as I have not been able to download a copy of the zip file that contains the kit image.
    Downloaded fine for me, Reese. Send me an email and I'll reply with a Dropbox link if you still need it.
  • Joe - just sent you an email. Thanks!
    Downloaded it the other day without issue. AMX.com can act up on occasion and seems much slower than it used to be when grabbing files.
  • I can`t download firmware files from site (SW2106_NX-X200_Master_v1_5_78 .zip). I tryed ten times.
    download alwayes is interrupted (((.
