Variable data type prefix
I am still in the learning process of programming AMX and I have inherited some code from an existing system. I am trying to comment/clean up as much as I can. Has anyone seen the 'b' prefix used before? The only word that comes to mind is 'boolean'. Example code below.
INTEGER bFireAlarmMuting
IF(nAnInteger){ //Evaluates true if 'nAnInteger' > 0 } ELSE{ //nAnInteger evaluates false if == 0 }I just put that out there that I often have 'states' stored in integers, with 'Off' being 0, but any other state having an index value. There's a chance that variable started as on or off, but maybe theres a state where the fire alarm was muted but not reset, etc.
The moral is... just because someone named it as a boolean, doesn't mean it' IS a boolean. If you experiencing issues, might be worth checking.
Z
