Custom event emulation
Not sure if I am missing something but I am unable to get custom event emulation to work. It''s not something I normally use so it could be a lapse of reason on my part.
NS4 is v4.4.1626
My test unit is an NX1200, running 1.5.78.
Async Notifications is enabled with ALL Devices and ALL options.
I get no notification if I use the Emulate Custom Event and also no notification if I use do_custom_event().
Am I missing the obvious?
    You need to create a tester in code first. One way is to crete a button event that fires the custom events based upon the button events. Then you can use Emulate A Device in NS to fire the button events that will then in turn fire the custom events.
