Integrate tracking position of physical object with AMX
marting
We need to track the position of a physical object (specifically, the adjustable base of a Sleep Number bed) and use that to affect code within AMX. Basically, when it reaches certain heights, we need AMX to send the TV lift to different presets.
Any ideas?
We were looking at draw-wire sensors like these but were not sure how we could integrate these with AMX:
http://www.micro-epsilon.com/displacement-position-sensors/draw-wire-sensor/MK_Serie/
Thanks!
Any ideas?
Thanks!
For this circuit the CSM1 was powered by AMX 12VDC, for other devices and/or other voltages the circuit may need to be modified.
Like how the wheel works on your mouse.
OR
A potentiometer on the bed and a Voltage Input Card, NXC-VAI4?
https://www.arduino.cc/en/Tutorial/AnalogReadSerial
