Simple While loop problem
vmail
Hi have a simple while loop and I don't know what's wrong, I want the contents of the Line variable spilt by commas to be placed in a structure.
The loop never stops, If I clear the contents of the Line variable in debug then the loop stops and the structure is populated.
Line = ",105,103,125,117,102,116,126,113,112,119,108,109,110,118" WHILE(LENGTH_STRING(Line) > 2){ Sources.ButtonNo[count] = ATOI(REMOVE_STRING(Line, ',', 1)) count=count+1 }
Another thing to bear in mind is that when you hit the last number, there is no longer a comma to remove. So "Line" will be stuck at 3 chars long. You might want to put the whole evaluation inside an if(find_string(Line,',',1)) statement. That way when you're on the last number you'll know because the find_string:comma will fail. you could do something like this:
Thank you.
The function REMOVE_STRING() is not the problem here. Your *logic* is the culprit.
Line 1: evaluates to TRUE if anything is in SOURCEDATA
Line 3: evaluates to TRUE if Obs Cabin2 exists in the Line variable.
Why should a FALSE for Line 3 automatically assume Line 1 is FALSE? They have nothing to do with each other.
Hi, Line 2 should be removing one line at a time from SOURCESDATA, when all lines have gone then line 1 should return FALSE.
Thanks....
