Pulling my code from my NI-3000
dsmithdsmith Junior MemberPosts: 30
I have a NI-3000 which is working fine but I had to format my PC's hard drive and I forgot to backup the folder used to store my current AMX code. How can I pull my current code off the NI?
Thanks, Donald
  • Danny CampbellDanny Campbell Senior Member Posts: 311
    Use the Receive tab in file transfer. Select the SRC file button, give it a name and tell it where you want to save it. Mapping should be 0:1:0 when it asks. After you get it go into Tools and select File Extraction and tell it you have a SRC file.
  • dsmithdsmith Junior Member Posts: 30
    Thanks Danny. Your directions worked like a charm.
