Telnet stopped working on a few NI-3100's ??
in AMX Hardware
I can still hook up a serial cable and terminal all day long.
but no telnet client will talk to it.
telnet is turned on and on the default port.
any thoughts?
John
any thoughts?
John
I don't know if it's been fixed yet but you need to enable SSH in order for telnet to work.
It's been reported to tech support.
Thats the second wonkiest thing if heard of this week!
And it worked.
Thanks!
John
Edit:
Now I have to go see what damage this latest firmware did to those clients I updated. I was hoping for some benefits but I should have known better! Actually if their telnet isn't working their daily logs aren't being written and my daily SITREPs will have no message attached. I guess I should have been looking at those attachments to notice they weren't there since the update.
After I re-enabled SSH I used telnet to to access the master and turn off SSH there (set ssh port > 0 > reboot). Although I could not telnet into the master after this, according to the webinterface SSH was still enabled. After a second reboot telnet just worked again... something does not seem right here. Probably won't be fixed, either.
Also using firmware 4.1.419
I doubt it will get fixed either and chances are my systems won't get upgraded to NX masters since I don't see a future in AMX so I don't even suggest upgrading when issues arise.
