ClkMgr: Invalid Time received from server.
vining
I have one system that still has this issue after switching both the master gui to use 129.6.15.28 at the top of the list and my date and time code which uses the astro clock functions. I double check again yesterday but again this morning I checked the daily log this system emails me and it still doesn?t receive a valid time. Other systems do using the same nist server IP. I hace both the master gui and my code set to query every 4 hours which is what the log shows so I don?t think it?s not likely something else buried in my code that I forgot about.
I suppose you might look into whether or not the Netlinx master can even get to the IP you're trying to reach. Perhaps do a ping from telent on the master to see if it can reach the destination? That might be a good starting point. Maybe your router/firewall is misbehaving. I dunno - you're in one of those odd places it seems to me.
I didn't even think of trying to ping but yeah pinging that IP didn't work from that master. That was time-a-g.nist.gov and neither did B but C & D did. Same from my PC so I don't why they've been working on the other systems. Bizarre!
