Virtual Device Limits?
lo1504
Hi,
are there known limits of
SET_VIRTUAL_CHANNEL_ COUNT
SET_VIRTUAL_LEVEL_COUNT
SET_VIRTUAL_PORT_COUNT
Line 787 2018-03-28 (13:23:19):: CIpEvent::OnLine 35001:193:1
Line 788 2018-03-28 (13:23:19):: CIpEvent::OnLine 35001:194:1
Line 789 2018-03-28 (13:23:19):: CIpEvent::OnLine 35001:195:1
Line 790 2018-03-28 (13:23:19):: CIpEvent::OnLine 35001:196:1
Line 791 2018-03-28 (13:23:19):: CIpEvent::OnLine 35001:197:1
Line 792 2018-03-28 (13:23:19):: CIpEvent::OnLine 35001:198:1
Line 793 2018-03-28 (13:23:19):: CIpEvent::OnLine 35001:199:1
Line 794 2018-03-28 (13:23:19):: CIpEvent::OnLine 35001:200:1
Same with channels and levels - only limit is going to be the the integer data type
Line 1 2018-03-28 (13:28:54):: Feedback:On [35001:1:1] - Channel 9999
Line 2 2018-03-28 (13:28:54):: Output Channel:On - From [35001:1:1] - Channel 9999
Line 3 2018-03-28 (13:28:55):: Feedback:Off [35001:1:1] - Channel 9999
Line 4 2018-03-28 (13:28:55):: Output Channel:Off - From [35001:1:1] - Channel 9999
Line 5 2018-03-28 (13:29:43):: Level Value To [35001:1:1] - Level 999 Value= 201
... but just because you can doesn't mean you you should.
And this is why I recommended the port count stay below 64. I've ran into issues when i've tried to go higher. I never bothered to suss out why or on which masters/firmware it seemed to happen. I've just found 64 seems to be the ceiling for some reason. Same thingwith levels. It seems like they quit working over 500.
