Home AMX RPM Forum
Controlling NEC PA622U projector over lan
Hi,
I just completed an RPM configuration on an Enova DVX switcher and the NEC PA622u I have installed does not respond to the control command through touch panel.
The projector is located about 40m away so I cannot use the serial port I am using the LAN
I noticed however that, when I enter the configuration menu on the touch panel, I am able to turn it off but cannot turn it back on again.
All the IP settings and configs have been done.
Any advice on what to do will be appreciated.
Charles
  • [Deleted User][Deleted User] Super Moderator Posts: 0
    I will have our ITG team look into the NEC module.
  • Hi the projector is a NEC brand and not Panasonic.
    The exact module drivers are on the AMX driver site and that is what I used or selected when I built the rpmx file, but the projector does not respond.
