Home AMX RPM Forum
Driver added from AMX Design Suite
Hi, I have created a new driver with Design Suite and added this to one of our test projects on the RPM cloud, the driver is available in our area and I have tested it with one of our RPM projects.
The driver is not working as I would expect and I would like to remove the driver from our area.
My two questions are:
Is it possible for me to remove this driver?
Does this driver only show in our Organization area on the RPM cloud?
  • [Deleted User][Deleted User] Super Moderator Posts: 0
    If you provide us the name of the Driver design file, I can have it removed. There is not yet a user method to remove a file. Any file you upload will only be seen within your organization.
