TPDesign4 - multiple instances
 PyroGuy
PyroGuy
            Good day!
I was wondering if it is possible to run mulitple instances of TPDesign4. I need to do some modifications from one TP4 file to another TP4 file. It would be nice if I could run TPD4 on 2 different monitors to make it easy to track and copy pieces from one file to other without flipping back and forth.
Any ideas?
Cheers!
It appears that you can't open multiple instances of the tool. But you can open multiple panel projects in one instance. You can set your monitor to SPAN, and open TPD4 across both screens, giving you a lot of area for pages.
Great John! Thanks for the suggestion.
I don't normally span my applications across both monitors but this is an example where I think I will do that! All the Best!
Michael
I almost always span my bottom two screens with with NS and TPD4. I need to see as much as possible at the same time instead of minimizing which bugs me.
