Importing/exporting a CSV file
How can I import/export CSV file from/to Netlinx master??
  • John NagyJohn Nagy CineTouch Product Manager Posts: 1,563
    edited March 2019
    You mean like using FTP? Filezilla is ideal but you can also use NetLinx Studio File Transfer.
    If you mean in some programmed automated way, be more specific on what you are trying to do...
  • janjan Posts: 3
    A client called me for an assistance. He wants to change the label/name of the buttons (for lighting control) on a touch panel. But the names/labels are on the CSV files. See below module part. I am new on this and I need some guidance. Thanks in advance
    MODULE_NAME='Module__Lutron_ZonenMgmt,Rev 1'(DEV vdv_Lutron_ZonenMgmt)
    (* CONSTANT DEFINITIONS GO BELOW *)
    DEFINE_CONSTANT
    // >> Lutron_ZonenMgmt KONSTANTEN <<
    CHAR cLutron_ZonenMgmt__CSV_PATH[] = 'Lutron_ZonenMgmt'
    CHAR cLutron_ZonenMgmt__CSV_FILE[][50] = {
    'Lutron_SzenenMgmt.csv',
    'Lutron_LichtMgmt.csv',
    'Lutron_StorenMgmt.csv',
    'Lutron_VorhangMgmt.csv',
    'Lutron_ZonenMgmt.csv',
    'Lutron_WetterAlarmeMgmt.csv'
    (* Die Namen, welche in der EXCEL Liste in der Formatierung <XXXX hinterlegt sind, hier eintragen! )
    CHAR cLutron_ZonenMgmt__ZONE_CMD_NAME[][20] = {
    Excel Scenen Management *)
    'KNXSCENE',
    'KNXSCENEORT',
    'KNXSCENENAME',
                            /* Excel Light Management */
                            'KNXLIGHT',
                            'KNXLIGHTNAME',
                            (* Excel Storen Management *)
                            'KNXSTOREN',
                            'KNXSTORENNAME',
                            'KNXVORHANG',
                            'KNXVORHANGNAME',
                            (* Excel Zonen Management *)
                            'KNXMGMT',
                            /* Excel Wetter/Alarme Management */
                            'KNXWEATHER',
                            'KNXALARME'
    (* DATA TYPE DEFINITIONS GO BELOW *)
    DEFINE_TYPE
    // >> Lutron_ZonenMgmt STRUCTURE DATENBANK <<
    //==> NEU: Structure DB ist im Handling definiert
    // Befehle werden mittels Send_String abgesetzt
    (* VARIABLE DEFINITIONS GO BELOW *)
    // >> Lutron_ZonenMgmt VARIABLEN <<
    VOLATILE CHAR cLutron_ZonenMgmt__CSV_BUFFER[499999] //CSV Einlese buffer
    VOLATILE CHAR bLutron_ZonenMgmt__ActivateDiagnostic = TRUE //Diagnostik aktivieren
    VOLATILE INTEGER nLutron_ZonenMgmt_ReadNextCSV
    (* LATCHING DEFINITIONS GO BELOW *)
    DEFINE_LATCHING
    (* MUTUALLY EXCLUSIVE DEFINITIONS GO BELOW *)
    DEFINE_MUTUALLY_EXCLUSIVE
    (* SUBROUTINE/FUNCTION DEFINITIONS GO BELOW *)
    //__ Sende an Diagnostik __
    DEFINE_CALL'Lutron_ZonenMgmt__Diagnostic'(CHAR cStringTxt[])
    IF(bLutron_ZonenMgmt__ActivateDiagnostic) SEND_STRING 0,"'#[Lutron_ZonenMgmt] --> ',cStringTxt"
    //__ CSV File Lutron_ZonenMgmt auslesen (select) __
    DEFINE_CALL'Lutron_ZonenMgmt__ReadCSV'(INTEGER nLutron_Group) //1=Szenen CSV, 2=Licht CSV, 3=Storen CSV, 4=Vorhang CSV, 5=ZonenMgmt CSV, 6=WetterAlarme CSV
    STACK_VAR SLONG slFileOpenResult
    STACK_VAR SLONG slFileReadResult
    STACK_VAR SLONG slFileCloseResult
    STACK_VAR SLONG slSetDirResult
    cLutron_ZonenMgmt__CSV_BUFFER = ''
    (* File öffnen *)
    slSetDirResult = FILE_SETDIR("'/',cLutron_ZonenMgmt__CSV_PATH")
    slFileOpenResult =  FILE_OPEN("cLutron_ZonenMgmt__CSV_FILE[nLutron_Group]",1)   //Only Read
    SELECT
    (* File öffnen erfolgreich *)
    ACTIVE(slFileOpenResult >= 0):
        CALL'Lutron_ZonenMgmt__Diagnostic'("'Open file ',cLutron_ZonenMgmt__CSV_FILE[nLutron_Group],' - success'")
        (* File einlesen *)
        slFileReadResult = FILE_READ(slFileOpenResult, cLutron_ZonenMgmt__CSV_BUFFER, MAX_LENGTH_STRING(cLutron_ZonenMgmt__CSV_BUFFER))
        CALL'Lutron_ZonenMgmt__Diagnostic'("'FILE_READ - Buffer lenght: ',ITOA(LENGTH_STRING(cLutron_ZonenMgmt__CSV_BUFFER))")
        SELECT
        (* File einlesen erfolgreich *)
        ACTIVE(slFileReadResult >= 0):
            CALL'Lutron_ZonenMgmt__Diagnostic'("'Read file ',cLutron_ZonenMgmt__CSV_FILE[nLutron_Group],' - success'")
            (* File schliessen *)
            slFileCloseResult = FILE_CLOSE(slFileOpenResult)
            SELECT
            (* File schliessen erfolgreich *)
            ACTIVE(slFileCloseResult = 0):
                CALL'Lutron_ZonenMgmt__Diagnostic'("'Close file ',cLutron_ZonenMgmt__CSV_FILE[nLutron_Group],' - success'")
                (* Schreibe Werte in die Datenbank *)
                CALL'Lutron_ZonenMgmt__WriteCSVinDatabase'
            (* File schliessen fehlgeschlagen *)
            ACTIVE(1):
                CALL'Lutron_ZonenMgmt__Diagnostic'("'Close file ',cLutron_ZonenMgmt__CSV_FILE[nLutron_Group],' - failed! / ErrorCode: ',ITOA(slFileCloseResult)")
        (* File einlesen fehlgeschlagen (Read Failed) *)
        ACTIVE(1):
            CALL'Lutron_ZonenMgmt__Diagnostic'("'Read file ',cLutron_ZonenMgmt__CSV_FILE[nLutron_Group],' - failed! / ErrorCode: ',ITOA(slFileReadResult)")
    (* File öffnen fehlgeschlagen (Open Failed) *)
    ACTIVE(1):
        CALL'Lutron_ZonenMgmt__Diagnostic'("'Set dir - failed! / ErrorCode: ',ITOA(slSetDirResult)")
        CALL'Lutron_ZonenMgmt__Diagnostic'("'Open file ',cLutron_ZonenMgmt__CSV_FILE[nLutron_Group],' - failed! / ErrorCode: ',ITOA(slFileOpenResult)")
    For clarity, are you saying the only goal here is to alter the text on touch panel buttons that presently is based on the name of an internal variable corresponding to actual file names?
  • janjan Posts: 3
    Yes
  • HARMAN_icraigieHARMAN_icraigie Technical Trainer II, Harman Professional University Posts: 544
    You can extract the file that needs to be edited through any FTP client - I use boring old Windows File Explorer more than anything else. Once the file is edited same applies for loading the file back to the master.
    https://digitalcitizen.life/connect-ftp-server-windows-explorer
    If you use Filezilla there’s protocol config that needs to be made on their FTP client, DOS modes or something, I’m not at my PC know so I can’t look and see.
    @jan said:
    Yes
    If you only want to alter button text, this isn't about import/export at all. It's about understanding dynamic touch panel design and management, sending text to display on buttons.
  • sentry07sentry07 Junior Member Posts: 76
    WinSCP is the best for all your file transfer needs. Just make sure to set the protocol to FTP when you connect to the netlinx master.
