Level bar graphs are not working
Dear All,
I'm trying to update the level bar graphs on some older NXD-500i's without success. These levels are come from a Precis Autoptach ( audio switcher ) and I keep the volumes on a float array Volumes[] for all outputs.
When debugging, I can see the "Volumes[]" values while they change from the range of -70 to 10.
So the data_event capture works perfect. The only thing I should finally do is sending the value to the panel bar graph.
A part of the code :
dvTP1 = 10021:2:20 //port2
dvTP2 = 10051:2:50
dvTP3 = 10052:2:50
dvTP4 = 10061:2:60
dvTP5 = 10062:2:60
volatile float Volumes[32] //32 audio outputs
volatile dvTPs[] = { dvTP1,dvTP2,dvTP3,dvTP4,dvTP5 }
data_event[dvPrecis]
string:
stack_var char nString[100]
stack_var char nStr1[100]
stack_var char nStr2[100]
stack_var char nStr3[100]
stack_var float nLevel
stack_var integer nOutput
     nString = data.text
//**Volume Feedback ** example 'CL0O8VA-300T' output 8 at level -30db
 if ( find_string(nString,'CL',1) and find_string(nString,'VA',1) and find_string(nString,'T',1) )
     nStr3 = remove_string(nString,'T',1)
     remove_string(nStr3,'O',1)
     nStr1  = remove_string(nStr3,'VA',1)
     nStr2  = nStr3
     nLevel = atof(nStr2)
     nOutput = atoi(nStr1)
     Volumes[nOutput] = nLevel/10    /from, -70 to 10
     send_level dvTPs,  nOutput, Volumes[nOutput]
    }   //volume feedback
For some reason, the bar graph level is going at the full position ( 100% ) regardless the value is sent (any value) and keeps staying there.
Again, the values taken from the data_event ( feedback ), are correct...!
Below you can see some notifications from N2S after a volume up command has been sent. You can see the
"Value= No Conversion for Double Precision" message. What does this mean exactly ?
In my code debugging, the Volumes[8] = -28
Line 1 2019-06-01 (16:19:18):: Input Status:Pushed [10021:2:20] - Channel 100 //volume UP
Line 2 2019-06-01 (16:19:18):: String To [5001:1:10]-[CL0O8VA-280T]
Line 3 2019-06-01 (16:19:18):: String From [5001:1:10]-[CL0O8VA-280T]
Line 4 2019-06-01 (16:19:18):: Level Value To [10021:2:20] - Level 8 Value= No Conversion for Double Precision
Line 5 2019-06-01 (16:19:18):: Level Value To [10051:2:50] - Level 8 Value= No Conversion for Double Precision
Line 6 2019-06-01 (16:19:18):: Level Value To [10052:2:50] - Level 8 Value= No Conversion for Double Precision
Line 7 2019-06-01 (16:19:18):: Level Value To [10061:2:60] - Level 8 Value= No Conversion for Double Precision
Line 8 2019-06-01 (16:19:18):: Level Value To [10062:2:60] - Level 8 Value= No Conversion for Double Precision
P.S> When sending a value - for e.g. "-28" - from the N2S "Emulate a Device", the bar graphs are working perfect !!
Any ideas please ?
George
    Why are the level values stored in a float? I have no experience with the Precis, but from your code snippet it seems you get -700 to 100 back from the device, so a sinteger would be enough.
    And when you send '-28' from 'emulate a device', do you also select float as the level type? If not, that could be the reason it works there.
    viningvining Posts: 4,368
    In my code it looks like I store the received value in a sinteger
    fnAP_FB_SendLVL(UI_UPDATE_ACTIVE,LVL_VOL_BAR_G,TYPE_CAST(((sAP_Zone[nLastOutPut].Volume / 10) + 70) * 1.25))
    I use a bar graph with a range of 0-100.
    It's probably just a matter of taste. Since in many cases we need to make some changes in the ways AMX does level ranges to how the device, as usual there are a couple ways to make this happen.
    1) is to force the level range in the TP file; changing the given range of the fader from the drfault 0-255 ($0-$FF) to whatever the device range is. Then when you send the raw fader values they line up nicely.
    2) (how I tend to do it) is to do the math in code so the range being sent to the touch panel ends up being 0-255.
    I tend to do the latter for the reason that I find that when I or someone later makes a new panel file or changes things the code continues to work more-or-less out of the box. In fact, In most things I try to write in such a way that if the box is changed or reset to factory values, it will still work. (when possible)
    Also, I take great pleasure in being able to run into my old Algebra teacher and saying, "I really do use this stuff every day."
    Hi All,
    thanks for your replies and suggestions...Answering your questions:
    1. I used float instead of sinteger because I needed the values being on negative decimal format
    2. When sending a negative value from "emulate a device", the bar graph works fine
    Finally, i made it work by removing the division of the value by 10 ( Volumes[nOutput] = nLevel/10 ). I just left it as it is ( Volumes[nOutput] = nLevel ) and changed the bar graphs range from -700 to 100.
    George
