WAP-200 issue?
in AMX Hardware
I recently replaced a bunch of consumer WAP's on a job with the AMX NXA-WAP200G to improve connections with my MVP's on the job. Mostly, all is well, but I am having trouble with one of them - it drops off the house network after 30 to 60 minutes or so. I can still access it wirelessly, but it won't talk to the rest of the network. Rebooting it solves the problem...for the next 30-60 minutes.
It's too early around here to call tech support, but I was wondering if anyone had any ideas - I have three access points in the house, and they are configured identically, except they are on different channels. Since the wireless portion remains up, the panels don't reconnect to any of the other points (which are fine), but the panel can no longer talk to the master. I am in a difficult spot here, having talked the customer into spending an additional $1200 for the upgrade, which is now less reliable (for different reasons) than his old $250 gear was.
Have you tried to swap channels with this unit and another WAP-200 that your using? or even locations?
I did get a hold of Tech Support though - and they said this was a known issue with old firmware versions. I'm reloading the firmware just in case, even though it reports current. They tell me it may just be a bad unit -rotten luck for me, but it happens.
At least, this time, my customer is being good natured about it.
i currently have an MVP-7500 that operated for months, now it dies within a day or so.
losses wireless. but my notebook wap services continue to work fine. so it's not the wap (in fact there are two in the house, both are fine)
this unit will go back today. i am also returning the desktop stand/recharger. the junction point between the two units is getting very hot. either the wireless is card is right behind that point in the case and overheating,or some power supply problem may be the cause.
This is super frustrating. All i know is that if i unplug the WAPs for awhile, 10 mins, and plug back in, the modero's connect again. It seems like the WAPs (at this clients) easily overheat. I don't know why, just thought i'd share this.
I also recall hearing (may have been a rumour) that the AMX WAPs are a result of colaboration with Cisco (they own Linksys).
Lastly, I know a guy that works at a large company. He is setting up a network with a few Linksys WAPs and I mentioned the problems I had in the past with them. The guy said he would check with their Cisco reps. (They have more than one Cisco rep dedicated to service the company). As of yet, I haven't heard a response regarding the issue and after a week of no response, they guy told me that normally means that there is most likely some sort of issue.
I leave it to you to draw your own conclussions and I must say that this is all personal experiences as I recall them and I make no claims as to the validity of this information in any way other than how it presented itself to me in the situations I am relaying.
