Aluminum smoke template?
Did AMX pull the aluminum smoke template or have they not released it yet?
I saw it in the ACE newsletter and figured I would try to get it when I downloaded the new panelbuilder. Panelbuilder doesn't find it and it's not on where the newsletter said to grab it..
Just curious..
Kevin D.
    You can update it on the site or through the install templete option on the program itself. Although you can update it it does not work . I keep getting error everytime I try to use for any type of panel. See attached image
    I just tried it and it did show up. I'm downloading it now and will let you know what I get..
    You did get the new panelbuilder right? I think the aluminum smoke uses the new chameleon buttons that requires the new version of panel builder and TP4..
    Kevin D.
    Everything works fine here.. Me likie chameleon buttons.. It's going to be nice having one design and changing it for each room..
    Kevin D.
    I whipped together a PanelBuilder file using Aluminum Smoke to check it out, but I can't look at it (and no, PanelPreview >doesn't< count) because the firmware needed to support this theme is only out for the 12/15/17" Moderos...
    Guess that's what I get for having a TPI4 for demos instead of a NXT_xxx. :(
