Timeline IDs and modules
I find myself using timelines more and more, as I discover just how wonderful they are. I find it's easiest to declare the constants for the IDs all sequentially in the main .axs to keep all the IDs straight.
My understanding is that apparently you can't pass a constant in the parameter list to a module, so if you wanted to have a timeline within a module, how would you get to its ID to be sure to set it to something different from what's in the main program? And if you used multiple instances of the same module, how could you get each ID to be different?
If you knew you were only ever going to use one instance of a module in a program you could always hard code the ID to be something high, like 99, unlikely to be reached in a program. Has anyone else been here before?
OP
OP
Oliver,
Of the two issues, let's look at the unique ID issue first. I use modules extensively and I also use timelines quite a bit (in modules). To solve the uniqueness problem, I define all of my TIMELINE IDs in an INCLUDE file (.axi) and then I include it in any module that requires a timeline. This way, I have a central location where all timeline IDs are defined, all modules have access to them, and you do not have to worry about the restriction that a module parameter must be a CONSTANT. As an aside, there used to be Netlinx runtime command that would dynamically return you a TIMELINE ID for use that was guaranteed to be unique. That call is no longer available and its demise probably had something to do with the fact that EVENTs required the devices, channels, levels, timelines, etc. to be defined at compilation time. Now that REBUILD_EVENT() is available which will re-compute the event trigger list, it would be nice to get that dynamic timeline ID call back for use in the multiple module instance as it would simplify things.
There are other ways to define your timeline IDs globally so as to ensure uniqueness and to then pass them into the modules. You could conceivably, although I have not tried this yet, define your timelime ID constants, put them into a non-constant array, and then pass the array into a module. You could then take advantage of the REBUILD_EVENT() to have Netlinx build the trigger list using the IDs defined in the array passed to the module. I have not tried this as of yet but conceptually I think it is workable.
I have encountered the multiple module instance/Timeline ID situation you noted. I handle this by defining a TIMELINE ID uniquely for the maximum number of module instances I ever expect to declare. When I define the module instance (whether it be in the Main program or elsewhere), I pass an integer value to the module which is essentially its instance ID. I then declare a TIMELINE_EVENT handler that triggers for all TIMELINE IDs that are defined for that module and then in the handler I check the TIMELINE.ID structure element to see if it corresponds to the TIMELINE ID for that module instance. In other words, using the TIMELINE IDs defined in the global header file, I create an array of those IDs that can be indexed by TIMELINE.ID. Since all of the timeline IDs I define for a module are sequential, simple math lets me determine the relative module instance for any given timeline ID. If the TIMELINE_EVENT determines that the event was for another module instance, the code is simply skipped. In other words, the TIMELINE_EVENT handler for the module encapsulates all of the code within an IF() statement that first ensures that the timeline event is for that instance of the module. It sounds more complex than it really is but it does work.
I have been meaning to go back and re-work some of the multiple module instances that use timelines to use REBUILD_EVENT() to see if it works correctly and if it simplifies the code.
Hope this helps,
Reese
This enforces that as long as modules keep multiple timelines inside the module unique, multiple modules (even multiple instances of the same module) with always will have unique timelines.
This reduces the burden on the programmer to keep from having to ensure unique IDs across modules, especially since some modules may not provide the source or documentation of what timelines are defined.
HTH,
Chuck
I haven't thought of an implementation, but is there a way to address the module timelines in the main program? Tell me there is a way to do this and I'll develop a problem that can be solved by it
Thanks all.
OP
Ok, no worries... saves me the time of developing a problem to fit the solution
As I typed my previous response, I just couldn't help but think about a solution to this nonexistant problem. You could have the timeline event in the module turn on/off a virtual channel and then in the main code or another module have a channel event that monitors this virtual channel. If the timeline was generating events every thousandth of a second, this would be a rather poor implementation, but if the timeline only triggered on the minute, it might be feasible. I'm still working on why you would need this functionality, but I have a solution should I ever find the problem.
Thanks to Oliver for starting the thread and for Chuck's input since I learned something I had never seen documented. I did not realize that the TIMELINE IDs were instanced and this can certainly be used in the future to simply my code where multiple module instances and timelines are used. It does however mean that TIMELINE_EVENTs will not behave like all other EVENT handlers where you can have multiple instances of them in different modules doing module specific code for the same event triggers. I am not sure that this is a significant issue (as Jeff said, tell us the solution for it and we will find a problem that requires it) but it does put TIMELINE_EVENTs in a special category of event in this reagrd. Since it is the only event not to use a DEVICE argument in the first place, I guess it has always been a little unique. I had never seen the module instance handling for TIMELINE IDs documented anywhere - would make for a very nice Tech Note.
Reese
