UPS monitoring
in AMX Hardware
i've started this thread as it became a subject here...
http://www.amxforums.com/showthread.php?s=&threadid=239&perpage=15&pagenumber=5
the UPS i use at the moment is a 500va unit, some generic brand.
the thing with the serial port on this unit and other low end units i've dealt with is....
it's not a real serial port. pin 3 is raised for power out, 4 is for ground, 5 is raised for low battery.
so simply take these outputs to the master controller IO and create log events for each condition (written into a text file)
very handy for showing customers what may be wrong with their house power.
might even want to turn on some emergency lighting, send an email, monitor/control generators.
there are benefits of the UPS having it's own reporting that's for sure. containing within netlinx is my personal preference.
and if energy management becomes a larger part of home automation, monitoring power reserves from alternate sources may be a 'feature' of the HA system.
all just an opinion, not set in stone of course.
