i!-Internet Database Plus
hi together.
i have some troubles with the internet inside application "database plus".
i try it on 2 different webserver's (IIS), with the same problem.
on the diagnostics i receive always "error 404 side not found"
the software makes correct the online connection to the webserver. i make the needed files with the included amx db-wizard, all directories and path's are correct, i can also connect to the website with my webbrowser and become the correct
syntax back (like on the help-file).
is there someone who can help me or have a solution?
thanks a lot
John
thanks a lot
John
I am trying to use i-Database Plus as well and am getting the same result. Anyone have any ideas?
Thanks!
Ian
Line 1 :: ADDING TO QUE: SELECT%20*%20FROM%20%5BEmployees%5D - 14:24:32
Line 2 :: Memory Available = 10365592 <10208> - 14:24:32
Line 3 :: Connected Successfully - 14:24:32
Line 4 :: Memory Available = 10349552 <16040> - 14:24:32
Line 5 :: OPENING CONNECTION TO localhost:80 ON LOCAL3 - 14:24:32
Line 6 :: CIpEvent::OnLine 0:3:1 - 14:24:32
Line 7 :: BUILD HEADER FOR LOCAL PORT 3 - 14:24:32
Line 8 :: HEADER=GET /employees.asp?hdr=all&sql=SELECT%20*%20FROM%20%5BEmployees%5D&ps=100&start=1&pnl=1 HTTP/1.0$0D$0AUser-Agent: Mozilla - 14:24:32
Line 9 :: Exiting TCP Read thread - closing this socket for local port 3 - 14:24:32
Line 10 :: CIpEvent::OffLine 0:3:1 - 14:24:32
Line 11 :: DB_GET_HTTP_HEADERS FINISHED PROCESSING - 14:24:32
Line 12 :: HTTP ERROR (404): Not Found - 14:24:32
Line 13 :: Document Error: Site or Page Not Found - 14:24:32
Line 14 :: $09$09Access Error: Site or Page Not Found - 14:24:32
Line 15 :: $09$09Cannot open URL - 14:24:32
Line 16 :: PROCESS HEADER FOR LOCAL PORT 3; HTTP CODE=404 - 14:24:32
Line 17 :: ACK QUE FOR LOCAL 3 - 14:24:32
I see the GET command is referencing a relative path, I would try changing the setup to reference absolutes and see what that does for you. That, or there is an environment variable that is supposed to be pre-pending a domain setting and it isn't set.
DB_INIT_CLIENT
(sDB_CLIENT,dvDB_CLIENT,'localhost',80,'/employees.asp')
when it should have been
DB_INIT_CLIENT
(sDB_CLIENT,dvDB_CLIENT,'172.21.1.128',80,'/employees.asp')
Thanks for steering me in the right direction!
